PreZidential Posted June 19, 2008 Report Posted June 19, 2008 Im looking at getting a system for my daily. Im looking for something loud, with good quality, but compact. I was looking at either, 2 12 Jlw7 , 2 12 Fi Q, 2 12 Fi Btl's Do btl's have good quality at lower volume as well as possible a louder volume? Can you run 3,000 watts on 2 12 Fi q's? Jlw7 vs Q... which is better? They appear to handle the same watts(12") but there has to be a differance in the two. Can you guys help clear this up for me? Or should i consider another sub that is "better" for my purposes.
etaks_crew Posted June 20, 2008 Report Posted June 20, 2008 I have heard all of these subs execpt the BTL's. I would go with the Q, the BTL's would eat 3000 watts like a jellybean. And the system that had the 2 W7 had two JL 1000/1's and I didnt think it was the impressive for the amount of money it cost.
AI James Posted June 20, 2008 Report Posted June 20, 2008 imo w7 over Q for nice sounding music with volume. look at the RE XXX, and ID max also
PreZidential Posted June 21, 2008 Author Report Posted June 21, 2008 Im looking for something with good power but has quality. I'm looking at maybe a 5,000 watt system... maybe powered by a hifonics goliath amp... or should i go with a rockford fosgate amp?
AI James Posted June 21, 2008 Report Posted June 21, 2008 either way out of what has been stated only the XXX's will stand a chance on that kinda power. you being a new user i wouldnt recommend 3k plus on a btl though as it doesnt "eat ir like a jellybean" unless you have a properly setup install and knowhow behind it
PreZidential Posted June 21, 2008 Author Report Posted June 21, 2008 3k is too much for 2 12 btls? The website states a rms of 2,000 per sub...
David Posted June 21, 2008 Report Posted June 21, 2008 nah you should be fine with 3k for 2 12's, I think james thought you were gonna dump 3k each, and I'll tell you right now unless your box is perfect or damn close, 3kw can kill a btl.
sonic purity Posted June 21, 2008 Report Posted June 21, 2008 You need to find the Funky Pups. Now thats a woofer n2caraudio.com
Sp33dyG Posted June 21, 2008 Report Posted June 21, 2008 wuts so special bout funky pup subs? (srry 4 being a n00b) the only person i wouldnt let build my box would be Ray. Team Heavy-Flex4 SA 12's tuned to 29hz Ampere Audio 3800.1 @ 1 ohmXS Power D3100Big 3Stock alt
etaks_crew Posted June 21, 2008 Report Posted June 21, 2008 either way out of what has been stated only the XXX's will stand a chance on that kinda power. you being a new user i wouldnt recommend 3k plus on a btl though as it doesnt "eat ir like a jellybean" unless you have a properly setup install and knowhow behind it Two BTL's would eat it like a jelly bean Edit not 3K each though that would smoke Tthe BTL's
