i need a help on wiring more than 1 amp....im thinkin on having (2) hifonics BXi 2008D..plus i already have (1) 600 watt dual 4 channel amp for my door speakers and rear....would i need more than 1 battery??...or will my stock battery handle it?..or a better alt?.or capacitors?...plz help.. :unsure:
I'm not familiar with the amps so I'm not sure what size power wire they take but I would run a 0 gauge off the batt into a distribution block and then run power wires to the amps for starters. What kind of stock batt do you have? Probably not tho. Also upgrade your big three.
Member since 25 Jun 2006
2011 Yukon DenaliCustomLightz 4300K HID RetrofitEsky TailsEsky Third BrakeEsky 22sEsky Appliques
each one is rated at 2krmw they really only do 15-1600wrms @ 1ohm and your gonna and least need 1 hc2400 and a 140+amp alt and then full tilt you'll drop to 12volts. I suggest getting atleast a 200amp HO alt and 2 hc2400.
My YouTube Videos
My Fiberglass A-Pillar Build
My feedback/references...
....i got a optima battery yellow top right now....so 4,000 watts aint gonna dim my lights??...how u upgrade ur BIG 3 bro??....
4000 watts will actually rape your lights lol.
You need to do some serious electrical work before you go installing everything. I learned the hard way on my first install. Dropped the volts down WAY too low and caused clipping. The voltage dropped to around 10.8 by accident. The clipping will heat up the internals of your subwoofer and eventually blow it/them.
Dont half ass the electrical. You will probably want to put around 1000$ into just the electrical of your car with an alternator, batteries, cable, terminals, etc.
tanx for da advice bro...kuld 1 hifonics 2000 watt amp handle two lvl 4 dc subs?....i wuz thinkin on having (2) lvl 4 subs wit (2) 2000 watt amps but if im gona need to upgrade my electrical den im jst gonna start jst wit (1) 2000 watt amp for now..and (1) lvl 4 sub....
just go with the Hifonics 2607d or 2608d. at least that'll give you a lil bit more than 2000rms
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
Jeez that's pretty heavy duty in my opinion... I had a 4.5kwrms system running off a stock alt and a single 8 year old yellowtop! Yes I had some voltage issues but I'm pretty sure if I had a new Yellowtop it wouldn't have been much of a problem.
If I remember right meade once had about 5000wrms off 1 yellowtop, stock alt and 2 RF 40F caps.
10.x volts fo' life!
0 gauge to both amps, and 4 gauge to the mid/high's amp
my mids and highs il just installed it....i just need the 2000 watt amp hooked in...but tanx 4 da advice thoug
  • Who's Online   0 Members, 0 Anonymous, 4261 Guests (See full list)
