I Need Help On Wiring More Than 1 Amp?..plz Help
i need a help on wiring more than 1 amp....im thinkin on having (2) hifonics BXi 2008D..plus i already have (1) 600 watt dual 4 channel amp for my door speakers and rear....would i need more than 1 battery??...or will my stock battery handle it?..or a better alt?.or capacitors?...plz help.. :unsure:
I'm not familiar with the amps so I'm not sure what size power wire they take but I would run a 0 gauge off the batt into a distribution block and then run power wires to the amps for starters. What kind of stock batt do you have? Probably not tho. Also upgrade your big three.
Member since 25 Jun 2006
2011 Yukon DenaliCustomLightz 4300K HID RetrofitEsky TailsEsky Third BrakeEsky 22sEsky Appliques
each one is rated at 2krmw they really only do 15-1600wrms @ 1ohm and your gonna and least need 1 hc2400 and a 140+amp alt and then full tilt you'll drop to 12volts. I suggest getting atleast a 200amp HO alt and 2 hc2400.
Vehicle: 1997 S10 Blazer 4dr 4X4
Exterior: Rear End Bagged, Black Grill, Lifted 2"
Amplifiers: Rockford Fosgate T8004 & T10001bd
Batteries: 2 Stinger SPV35, Kinetik HC2400
Electrical: Big 3, DC Power 290amp Alternator w/ MLA at 15.5v
Enclosure: 4.2 ft³ @ 33Hz 84sq.in. of port (20sq.in. per cube)
Headunit: Eclipse CD3200 w/ 80G iPod
Mids/Highs: Rockford T152s (a-pillars), Rockford T162s (doors)
Subwoofers: 1 15" Fi BL Fully Loaded
Wire: All 1/0g Kicker Hyperflex
My YouTube Videos
My Fiberglass A-Pillar Build
My "Seamless" Looking Box Build
My DD1508 T-Line Bandpass Build "Seamless" w/ Acrylic Windows (for '05 TrailBlazer)
My Stealth 8" Fiberglass Build (for '05 TrailBlazer)
My Build For A Friend's '08 Cobalt 15" BL Sealed Off From The Trunk
My feedback/references...
....i got a optima battery yellow top right now....so 4,000 watts aint gonna dim my lights??...how u upgrade ur BIG 3 bro??....
4000 watts will actually rape your lights lol.
You need to do some serious electrical work before you go installing everything. I learned the hard way on my first install. Dropped the volts down WAY too low and caused clipping. The voltage dropped to around 10.8 by accident. The clipping will heat up the internals of your subwoofer and eventually blow it/them.
Dont half ass the electrical. You will probably want to put around 1000$ into just the electrical of your car with an alternator, batteries, cable, terminals, etc.
tanx for da advice bro...kuld 1 hifonics 2000 watt amp handle two lvl 4 dc subs?....i wuz thinkin on having (2) lvl 4 subs wit (2) 2000 watt amps but if im gona need to upgrade my electrical den im jst gonna start jst wit (1) 2000 watt amp for now..and (1) lvl 4 sub....
just go with the Hifonics 2607d or 2608d. at least that'll give you a lil bit more than 2000rms
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
Jeez that's pretty heavy duty in my opinion... I had a 4.5kwrms system running off a stock alt and a single 8 year old yellowtop! Yes I had some voltage issues but I'm pretty sure if I had a new Yellowtop it wouldn't have been much of a problem.
If I remember right meade once had about 5000wrms off 1 yellowtop, stock alt and 2 RF 40F caps.
10.x volts fo' life!
0 gauge to both amps, and 4 gauge to the mid/high's amp
my mids and highs il just installed it....i just need the 2000 watt amp hooked in...but tanx 4 da advice thoug
  • Who's Online   1 Member, 0 Anonymous, 1482 Guests (See full list)
