htx kustoms Posted June 21, 2008 Report Posted June 21, 2008 This is the box I want to build for my Magnum its pushed all the way back and i still want my cargo space its for 2 12" P3's I have the box at 4.37 my where would i put the port if i cant go ported a sealed box at 2 cu ft would fit perfect but performance wise im not to sure...
babyjoker Posted June 22, 2008 Report Posted June 22, 2008 you can put the port on the side, what size port u looking at? 1999 Eclipse N/T 12'' Fi BTL Gp3000d PM D3100
wL<3bass Posted June 22, 2008 Report Posted June 22, 2008 I would build that box and put a divider in the middle and fire the two ports out the bottom to the side.... Vehicle: 1997 S10 Blazer 4dr 4X4 Exterior: Rear End Bagged, Black Grill, Lifted 2" Amplifiers: Rockford Fosgate T8004 & T10001bd Batteries: 2 Stinger SPV35, Kinetik HC2400 Electrical: Big 3, DC Power 290amp Alternator w/ MLA at 15.5v Enclosure: 4.2 ft³ @ 33Hz 84sq.in. of port (20sq.in. per cube) Headunit: Eclipse CD3200 w/ 80G iPod Mids/Highs: Rockford T152s (a-pillars), Rockford T162s (doors) Subwoofers: 1 15" Fi BL Fully Loaded Wire: All 1/0g Kicker Hyperflex My YouTube Videos My Fiberglass A-Pillar Build My "Seamless" Looking Box Build My DD1508 T-Line Bandpass Build "Seamless" w/ Acrylic Windows (for '05 TrailBlazer) My Stealth 8" Fiberglass Build (for '05 TrailBlazer) My Build For A Friend's '08 Cobalt 15" BL Sealed Off From The Trunk My feedback/references...
ISO Posted June 22, 2008 Report Posted June 22, 2008 Do oyu want slot ports or circular ports(PVC pipe)? If slot ports I would go with them on the back wall of the box fireing up because its less complicated to build. Ports on the side: One important rule is you can't port into an unequivilant area. EX: If you use a 4 inch diameter port on the side of the box you need a 4 inch bare minimum air gap between the port and the first solid surface or side wall of the vehicle. 3 inch port,need 3 inch gap and so on and so on. Isobaric - Refers to the practice of coupling two drivers together to make them act as one. "Giving up doesn't always mean you are weak; sometimes it means that you are strong enough to let go." Insanity: doing the same thing over and over again and expecting different results. The Destruction of a person builds character.
