I'm going to be building a box with in the next month or two and the max dimensions i have are 36" wide, 24" depth, and 19" high. well my problem is im not sure how/where to mount them. considering if i had a port 5 inches wide. that wont leave me enough to have the 15's mounted side by side. and im sceptical(sp) on making the port smaller. Anyone have any ideas?
have the 15's slightly angled toward each other...kinda like a clamshell would be. you could have a width of about 20-25 inches for both 15's depending on how much you angle them....know what im sayin.
i was thinking leave the 12 sitting in the box in the hole and duck tape from the bottom of the sub to the bottom of the baffle so the sub doesnt free air. would that work?
why? all you have to do is cut the side of the piece that will be angled at an angle so that it will set flush against the front baffle. then for the top and bottom just have it come all the way out like it was a regular box. you could even lay some mirror on the bottom. just gotta use your imagination ;)
just an idea...:lol:
I'd do what Randy said. You can get more port area that way and you won't have phasing issues. I can see that angled one having cancellation and phasing issues inside the box because one sub Is pretty much free-airing into the port while the other has sort of a loading wall.
HU: JVC KD-AVX1Speakers: Stock BlazerSub: 2 Mass Destruction Car Audio Sidewinder 12"Amp: Orion HCCA-D1200 @ 1ohm (600 RMS)Box: 3.0 cubes tuned to 35
Heres my super cool idea :P
My YouTube Videos
My Fiberglass A-Pillar Build
My feedback/references...
Or just use aeroports at the bottom like this [o:o] so you can fit them.
My YouTube Videos
lol at the drawing
u may have to do wut im doin (if ur puttin in a trunk or sumthin like that) port it through the rear deck
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
  • Who's Online   0 Members, 0 Anonymous, 2418 Guests (See full list)
