Battery Question
so ive seen everybody puttin 2+ batts in their vehichles.
and someof them are diff than the front batt.
i always thought they all had to be the same exact batts or one of them would never get charged right.
so am i wrong or do they use an isolator or something?
First Gen Xterra: Always changing
DNX 690HD
RF 360.3
RF T3002
RF T4004
RF T10001bd
Silver Flute 6.5"s
Tang Band 1" Tweeters
Sundown X18 in 7cubes net tuned to 32hz
Trust me .25 Blows your Load.
i think the rule is to have all new batteries of the same type like agm. and not to mix agms with regular batts. you can mix them but its not recommended .say you had a stock batt under the hood and you installed 2 power masters in the trunk .stock or normal batts rest at like 12.4 and the agms are more like 13. and above.thats from what i have read. hope it helps :huh:
I am running a stock up front and an hc2400 in the rear and have had no issues. Plan on upgrading front battery, but the shop I bought the 2400 from said there should not be any issues. In fact, you can call kinetik or powermaster and talk to the tech department. I did that with ohio regarding a big three wiring issue.
Loud as f*ck, and sounds good doing it.
Team built from here on out!!!!
BIG things to come.........
Missing link is the shite!!!
There is no problem mixing batteries, we do it all the time. It is better to have all AGM if possible, becauase the resting voltage of a flooded battery is lower than an AGM, so it won't perform quite as well. From a safety/functionality standpoint, there is no problem though.
so apparently it dont have to be the same battery.
thanks yall
DNX 690HD
RF 360.3
RF T3002
RF T4004
RF T10001bd
Silver Flute 6.5"s
  • Who's Online   0 Members, 0 Anonymous, 4089 Guests (See full list)
