Subwoofer Help
I have recently retired my 4 10" MTX subs( 4 ohms). They were barely used so I though I would run them in my home theater. I was going to run them off of a Crown XTi 1000. My questions are..... Do I need anything special to do this or will the x-over in the amp be fine? My reciever is a Denon AVR 3805. Also is there anywhere I could get some home sub box plans, ideas? And of course anything someone cares to chime in on would be awesome. Thanks guys, I don't log on as often as I should, but I check the site everyday and all you guys kick ass!
Use the X-over on the amp....should be good
I'm not really knowledgeable about home audio as alot of ppl but I read that if you are going to use a "car" sub in a home application that the box needs to be 50% larger than the recommended size.
I know thats not your question I just thought I would throw that little tidbit of information out there....if it's inaccurate than someone feel free to say so.
My YouTube Videos
My Fiberglass A-Pillar Build
My feedback/references...
Thank you guys, any info is greatly appreciated. I have heard that about the enclosure size too, but luckily size won't be an issue.
Just build the box to whatever MTX tells you to...car or house the box remains the same...also what ohm are you running that amp??
The speakers are 4 ohm the amp is 1,000@ 8 ohm and 1400@ 4 ohm.....I think either one would be plenty. Any suggestions?
Ive also heard for home boxes, build the box large. My uncle built one for a 15" kicker comp at 5 cubes and ported it to 28hz. it doesn't get uber loud, but adds the rumbles needed for movies while adding decent bass with 100 watts. His fires with the sub towards the wall and slot port out the upper half of the box towards the room. [on its side it makes a good place for drinking games :rolleyes: ]
are they dual four or single four ohms?
Current Setup:
Factory HU with LOC
mids/highs-Insignia components
Sub- E8 in bass tube
Amp- sae-1200d
Show Setup:
HU-Sony MEX-1HD (brings massive respect for sony)
fronts - Infinity Kappa perfect comps
rears- Infinity Kappa coax
mid/high amp - Autotek 5600
Subs - 2 RE SE 15's
Sub Amps - 2xSAE-1200D
Box - 5cubes sealed
Wire- Lots of Knu 1/0
SECOND SKIN
There is a huge difference accoustically between home and car
for optimum sound, dedicated LOW end subwoofers, and dedicated woofers are pretty important in movie sound reproduction...
Basically because you have a larger room in a home, you may want to tune the subs at like 25hz and then the woofers at 50hz (woofers meaning tower speaker bass drivers, or secondary sub woofers- preferably an octave apart)
If you follow that simple guidline there with subs and woofers, you will have a nice clean transition between explosions, and music, and rap/jazz/rock, a nice wide bandwidth on the bass range which is harder to keep flat in a large room that is 15ftx15ft other than a car that is 4ft wide and 9ft deep
I did a lot of work with home audio enclosures, tower speakers from tweeters to the subs, cross over designs and cabinet designs, and besides tweeter and midrange imaging, and cross over slopes, the transition from mid bass and sub bass is pretty important
They are just single 4 ohm. Forevebumpn I might be bugging you a little bit later on with some questions if you don't mind. Thank you all for your input it is greatly appreciated.
