so i am working on a setup with 4 15's and i need to figure out how to prevent canceling... the box is setup with the subs facing eachother making a square i have top sub wired regular bottom sub wired negative to positive positive to negative...fixed those two now the question would wiring left and right the same way as top and bottom work?
thanx for all your help
R.I.P. SONOMA
I WILL FIND WHO STRIPPED MY BABY!
just wire them all the same so they will be in phase.(sp)
Need any thing chromed? Hit me up!!!
gamer tag: (360)
mEmEnToMoRi64
My Myspace
refs:
from here: RollinSoLow, Derrick824, Ray
from c.a.c.o. : teamsubgopoof, splvictim20, SundownAudioNY
from C.A.J. : Donpisto, spladdict19, CAJunkyard, JBLCAMRY, DasBot (robot underground)
from ca.com: alxmlr789,photocrazy8
with out a picture of the setup its hard to say anything.
I would wire all of them in phase and test it out.
something along the lines of this? can you explain phase wiring?
R.I.P. SONOMA
why would you build it like that?
your more than likely gonna have some issues.
your just gonna have to play with it and figure it out on your own.
phase wiring, is when all the subs are moving at the same time and the same direction, one moves out they all move out. prefferably wire them all with the corect + and - connections
Current Setup:
Factory HU with LOC
mids/highs-Insignia components
Sub- E8 in bass tube
Amp- sae-1200d
Show Setup:
HU-Sony MEX-1HD (brings massive respect for sony)
fronts - Infinity Kappa perfect comps
rears- Infinity Kappa coax
mid/high amp - Autotek 5600
Subs - 2 RE SE 15's
Sub Amps - 2xSAE-1200D
Box - 5cubes sealed
Wire- Lots of Knu 1/0
SECOND SKIN
well its sounds like balls cause they cancel..
and changing box setup isnt really an option i used every bit of space.
so i guess playing with it is my only option. for right now the top and bottom sound good so ill do the same thing with left and right to see how it works out.
R.I.P. SONOMA
  • Who's Online   1 Member, 0 Anonymous, 707 Guests (See full list)
