IH8PunkRok Posted July 2, 2008 Report Posted July 2, 2008 ok so this is my first time messin wit a head unit. all i can say is holy shit. too many connectors and adapters that dont fit. *headache* but i got it done and it worx great so im happy. onto the pics. For those that expect people on forums to walk u step by step through an install, i have one pic for u KD-AVX1 manual and the mustang manual. learn to use them Soldered and shrink tubed Ignore the wires i gotta find a cover for that hole where my cd player used to be so yea there it is. im happy. i still gotta get used to it but thatll come soon enough, -Matt2005 Dodge Magnum RTJVC KD-AVX1 2 PPI S580.2 Obsidian Audio ST1 Horn Tweeters PRV 8MB450s Audio Legion 3500.1D 2 RE MT 18s 360 ah LiFePO4 BatterySHCA 2/0 155.2 @ 29 hzKicker CVR 15's buildDD 3512e buildMini T-Line Build(6) 8s BuildNightshade 15s Wall BuildMagnum AB XFL 12s BuildNewest Magnum Build
FieroGrande Posted July 2, 2008 Report Posted July 2, 2008 Good to see you got it installed but it looks like the white wire isnt completely covered by the shrink tube
BigPimpin91 Posted July 2, 2008 Report Posted July 2, 2008 How much did you spend on that? BigPimpin91's Banging Music
treossi Posted July 2, 2008 Report Posted July 2, 2008 what did you use to shrink it? you should go back and fix that white wire Team sundownWESTCOASTSPL.COM we're throwing dbdrag events very soon visit the website for details
Stephen Posted July 2, 2008 Report Posted July 2, 2008 Good to see you got it installed but it looks like the white wire isnt completely covered by the shrink tube x2 maybe get a small piece of abs to fill that hole............ a flush mount stinger meter would look good there you can cook bacon shirtless if you're not a pussy...lol not hatin, but am i wrong here it looks as if the amp is not grounded its hooked directly to the battery. it that the way it should be. DC POWER
Audiobahnaholic Posted July 2, 2008 Report Posted July 2, 2008 That white wire is just a speaker wire. As long as it's not touching anything (looks at though it's all plastic in there) he should be fine. One thing I'd do if I was you is I get that 3/4" heat shrink and run all my wires through it and then shrink them all together so you've got one cable from the headunit then your different RCA's. Makes hooking things up to the RCA's a lot easier because you don't have to fish through wires. Just make sure if you do this all your connections are secure and no bare wires to short each other out. HU: JVC KD-AVX1Speakers: Stock BlazerSub: 2 Mass Destruction Car Audio Sidewinder 12"Amp: Orion HCCA-D1200 @ 1ohm (600 RMS)Box: 3.0 cubes tuned to 35
IH8PunkRok Posted July 2, 2008 Author Report Posted July 2, 2008 Good to see you got it installed but it looks like the white wire isnt completely covered by the shrink tube what did you use to shrink it? you should go back and fix that white wire i actually fixed that this morning. last night i was tired and decided to leave it but this mornin i said alright ima fix it. i cut the solder re stripped it and covered it up again. and i used a heat gun to shrink it. audiobahn i wish i had some shrinktube that size but i dont. its a good idea though. i used zip ties to hold everything together. -Matt2005 Dodge Magnum RTJVC KD-AVX1 2 PPI S580.2 Obsidian Audio ST1 Horn Tweeters PRV 8MB450s Audio Legion 3500.1D 2 RE MT 18s 360 ah LiFePO4 BatterySHCA 2/0 155.2 @ 29 hzKicker CVR 15's buildDD 3512e buildMini T-Line Build(6) 8s BuildNightshade 15s Wall BuildMagnum AB XFL 12s BuildNewest Magnum Build
IH8PunkRok Posted July 2, 2008 Author Report Posted July 2, 2008 x2 maybe get a small piece of abs to fill that hole............ a flush mount stinger meter would look good there i cant find anything to put in that hole. i feel like a noob but wuts abs? and where can i get it? -Matt2005 Dodge Magnum RTJVC KD-AVX1 2 PPI S580.2 Obsidian Audio ST1 Horn Tweeters PRV 8MB450s Audio Legion 3500.1D 2 RE MT 18s 360 ah LiFePO4 BatterySHCA 2/0 155.2 @ 29 hzKicker CVR 15's buildDD 3512e buildMini T-Line Build(6) 8s BuildNightshade 15s Wall BuildMagnum AB XFL 12s BuildNewest Magnum Build
Aaron813 Posted July 2, 2008 Report Posted July 2, 2008 i actually fixed that this morning. last night i was tired and decided to leave it but this mornin i said alright ima fix it. i cut the solder re stripped it and covered it up again. and i used a heat gun to shrink it. audiobahn i wish i had some shrinktube that size but i dont. its a good idea though. i used zip ties to hold everything together. you can get a shrink wrap kit from walmart or autozone for a few bucks and it comes with a bunch of different size shrink tubes
Stephen Posted July 2, 2008 Report Posted July 2, 2008 i cant find anything to put in that hole. i feel like a noob but wuts abs? and where can i get it? http://sonicelectronix.com/item_6747_Plast...+20-+x+15-.html you can cook bacon shirtless if you're not a pussy...lol not hatin, but am i wrong here it looks as if the amp is not grounded its hooked directly to the battery. it that the way it should be. DC POWER
