ok, here you go. I have no clue what the cubic feet of the enclosure was, but I agree with the small enclosure, bigger vent. I saw a crx with a cute little vented enclosure with one 8 inch l7 on 1500 watts positioned in the drivers side, rear corner of the vehicle and did a 150.something. Seriously!!!!!! For raw spl, small enclosure, bit vent will do wonders. I will try and get measurements on 8/2 here in kcks at the next comp. But he did a 150+ with an 8"l7 on 1500 watts in a tiny vented enclosure. Saw it with my own eyes man.
Loud as f*ck, and sounds good doing it.
Team built from here on out!!!!
BIG things to come.........
Missing link is the shite!!!
i'm running 2 10 not just one i have a stock alt 65amps stock batt with 2 red tops and 2 1/2 fard caps on 1/0 ga wire no fuse and it's in a 94 eclispe meca has put me in m2 class because i have no back seat
ADD FUSE!!!!!! NO FUSE, NO GOOD!!!!!! Do you like to watch cars on fire? I like to, but not mine. Save your car's life and put a fuse as close to the battery 's as possibe. After the front one, and right before the second one. Then when coming off of the second one, put a fuse as close to the battery as possibe going to the amps. And the guy running the 1 8inch l7 did not have a back seat either. Just was saying to do some research for pure spl because bigger is not necessarily better for all out spl.
my amp is a kicker 1200.1 subs are dual 2 ohm right now i burp at 45 hz and yes that all i want to do is burp
Get more power, and diff amp where you can run it at .5 ohm for burps with your dual 2s
Than we'll talk about box
2004 Explorer4 12" Type R500.1(.5 ohm)6cu@35hz153@ 44hz
the amp is runing fine at .5ohm has been for a year the only problem i have is th alt is going out but i've had it for 4 years stock 65 amps
Start by tuning way higher.
Burping at 45hz is way low. Should be up around 60+ ideally.
If he is doing MECA then I can almost guarantee that 60 hz would not be a good frequency. Nearly everyone that meters at the headrest is peaking below 50 hz.
1992 GMC Sonoma
2008 MECA S1 Champ, 2010 MECA S2 Champ
I wonder about the small box big port theory.
Any of you guys seen pics of the Ford Ranger extended cab Kicker was playing with to make 2 8 inch L7s do 150db.
The box took up the whole extended cab area and the port was damn big too.
Can't find a link though.
Isobaric - Refers to the practice of coupling two drivers together to make them act as one.
"Giving up doesn't always mean you are weak; sometimes it means that you are strong enough to let go."
Insanity: doing the same thing over and over again and expecting different results.
The Destruction of a person builds character.
  • Who's Online   0 Members, 0 Anonymous, 2309 Guests (See full list)
