ISO Posted July 9, 2008 Report Posted July 9, 2008 (edited) I just caught this mistake I made, the subs I'm looking at are 10's. I just caught that, and they're putting out 300 each. + I found an enclosure that would work perfectly. so should I still stick with the Kicker 750.1 or I think I could pull out enough cash for the RF 600.1? Which would be better? It really comes down to what the final ohm load is. The Kicker will except a 2 ohm load. The RF punch P500-1bd will except 1 ohm. I'm not sure what the RF 600 can take as its discontinued. 2 dual 4 ohm subs will give you a 1 ohm load. 2 dual 2 ohm subs will give you a 2 ohm load. Edited July 9, 2008 by ISO Quote Isobaric - Refers to the practice of coupling two drivers together to make them act as one. "Giving up doesn't always mean you are weak; sometimes it means that you are strong enough to let go." Insanity: doing the same thing over and over again and expecting different results. The Destruction of a person builds character.
JustinT Posted July 9, 2008 Report Posted July 9, 2008 I think here is a good cheap amp for you if I figured out the ohm load right http://www.woofersetc.com/index.cfm?fuseac...Product_ID=5223 Quote "IT SOUNDS SLOW MOTION AND STUTTERING"~~~~LOL 2 15" Fi BTLs 7.5 cf box @ 33hz Sundown SAZ-3500D Powermaster S3400 & D3100 Iraggi 300a alt SecondSkin - totally dead Knu wire
