i was thinkin that also but aint the remote wire just a constant 12v or does it regulate with the power in from the battery? and how many amps are they?
Edited by tacomabanga1986
here's a link to my system 99 toyota tacoma , 2 mtx 8000 1504's in a sealed downfire , 1000w memphis amp
here's a link to my other system my 90 geo prizm test car
heres a thread i got of new songs u can dl that are legal = Some Good Bangage/you Can Dl These Free And Legit
Wow its very important that you are useing a Relay on the remote wire to get a hard positive.
When you have done that the power going to the amps is the same as being directly hooked up to the battery.
Isobaric - Refers to the practice of coupling two drivers together to make them act as one.
"Giving up doesn't always mean you are weak; sometimes it means that you are strong enough to let go."
Insanity: doing the same thing over and over again and expecting different results.
The Destruction of a person builds character.
oh wow... LOL
If the remote wire was a constant 12v your amps and anything else would be on all the time.....
Its called remote for a reason, it turns things off and on like a remote control.
Remote wire puts out almost no amps, it is a very weak 12 volt wire. If you are running more then 2 accesories off your remote wire, you should look into running a relay or you may run into problems of not having enough power to turn on all your components, or they may start turning off when voltage gets lower from a large bass note.
  • Who's Online   0 Members, 0 Anonymous, 4203 Guests (See full list)
