Ok i got a stinger voltage meter and where do you guys hook the power wire as in the red wire to get the right voltage fuse box or run them to the battery where?
Thats what i thought to thax man.
You will need to run it to a switched 12V source, otherwise it will stay on all the time, and could eventually run your battery(s) down. Any cicuit on your fusebox that is hot only when the key is in the "on" position will work fine.
Are these volt meters accurate?
My YouTube Videos
My Fiberglass A-Pillar Build
My feedback/references...
Well i know the Blue is key turn on Red goes to your batt i guess and Black is ground and yea i tested this voltage meter to see if it was right and yea it was never had to adjust it at all.
The one on my RF CPCC1 is only off by 0.01.
Some are good some arn't that great.
Same storie- you get what you pay for.
Isobaric - Refers to the practice of coupling two drivers together to make them act as one.
"Giving up doesn't always mean you are weak; sometimes it means that you are strong enough to let go."
Insanity: doing the same thing over and over again and expecting different results.
The Destruction of a person builds character.
what ied do is wire the blue wire to the red wire on ur headunit, the red to the yellow wire on the headunit, and black on the headunit and should work that away thats how ied do it but then again wont that register off the front battery how would u kno about the back battery or buy 2? ive been wondering this for a while
here's a link to my system 99 toyota tacoma , 2 mtx 8000 1504's in a sealed downfire , 1000w memphis amp
here's a link to my other system my 90 geo prizm test car
heres a thread i got of new songs u can dl that are legal = Some Good Bangage/you Can Dl These Free And Legit
You have alot of options to work with.
You can grab the power rite off you ignition wire.
I have a relay on my remote wire for a hard positive so I would probly just hook it up to the remote turn on lead for my amps.
  • Who's Online   0 Members, 0 Anonymous, 4089 Guests (See full list)
