I am getting a sub today (RE Audio SE 10") and was wondering what one I need to get a 1 ohm load bridged? Do I need the dual 2 or the dual 4.
Remember I am only buying 1 (ONE) sub.
PPI dbl din
DC Level 3
1.77cubes net tuned to 33htz.
DC audio 2.0k
Get duel 2, wire it in parallel for a presented load of 1 ohm to the amp
~Matthew
1998 Toyota Camry XLE V6 3L
(1) ScyTek Astra 4000RS-2W-1 2-Way Remote Start Alarm
with Shock and Proximity
(1) 20% Tint All Around (Gately Audio)
(1) 250 Amperage HO Alternator
(1) Big 3 Done In 1/0
(2) Kinetik HC2400 Power Cell
(1) Alpine IVA-D106 Receiver
(1) Peripheral Video Bypass Device
(4) Alpine SPS-17C2 Speakers
(1) Alpine KCE-422i iPod Control Interface
(4) Sheets Dynamat Extreme; for speakers
(1) 10 Square Feet Hushmat (Trunk & Rear Deck)
(4) DC Audio Level 4 15" D2 Subwoofer w/ Level 5 Coils
(1) Wall Built By David, Tuned to 32 Hz
(1) Rockford Fosgate T40001bd Amplifier
(1) Stinger 1/0 Wiring (2 runs of + 2 runs of -)
(1) Stinger Volt Meter
You just need a dual 2 ohm sub to get get 1 ohm out of a single sub.
D2 = 1 ohm and 4 ohm
D4 = 2 ohm and 8 ohm
Isobaric - Refers to the practice of coupling two drivers together to make them act as one.
"Giving up doesn't always mean you are weak; sometimes it means that you are strong enough to let go."
Insanity: doing the same thing over and over again and expecting different results.
The Destruction of a person builds character.
You beat me to it. LOL
EDIT
better anyways so that he knows its right - if 2 ppl say the same thign you know?
Edited by Bass4Lyfe
~Matthew
EDIT
So true so true
Thats not gonna be good my man. By the sound of it your trying to hook this woofer up to a multi channel amp. Most a/b mulit channel amps are only stable bridged at 4ohm, most will do 2 ohm bridged with out shutting off or going tinto protect. But 1 ohm load bridged will most likly cause your amp tp pop into protect often or cause damage to the amp it self
TEAM SUNDOWN
4 Nightshade 15"s
2 Sundown SAZ-4500
8 Deep Cycle batts
1998 Cadillac Catera
SPLMAX CUP 2008 Fourth Place Overall
goot point kb .. .didn't even think of that ... bro just find a 1 ohm stable amp, class D
~Matthew
its .5 ohm stable mono and 1 ohm stable bridged. which will give me get this 2500watts. to a sub that has a max of 600....
i will have no problem with the amp at 1 ohm.
PPI dbl din
DC Level 3
DC audio 2.0k
