differences in output. if a port is too small...it could cause some port noise since it causes the air to 'squeeze' through. like pinching a straw and trying to drink out of it.
general rule of thumb is 12-16 inches of port per cubic foot. so depends on how big you're making the box
Is that just for 12s or dose that apply for everything. I would assume everything
03 Trailblazer EXT LT
In Dash
Rear Flip Down
Polk Audio Font & Rear Stage
Hifonics Zeus 4 Chan Amp
Hifonics Brutus Mono Amp
12" Rockford Fosgate Power HX2
T-Line tuned to 45hz
18"BTL T-line @31Hz (9 weeks pregnant)
i've been under the influence that it was generally the same for all? my 8's have 12 sq inches of port per cubic foot.
Edited by ExpoSport
what would you recommend for port area for 10s 12s and 15s?
In Dash
Rear Flip Down
as mentioned above, it depends on volume. 1 10"? or 8 10's? i read on here for SPL they got the best results from a little box with a big port. so if that's the case then you'd wanna go on the higher end of sq inches for port. of course it's not limited to 12-16 sq inches tho. that's where testing and testing and testing comes into play.
but to answer your question:
8" - 12 sq inches
10" - 13 sq inches
12" - 14 sq inches
15" - 15 sq inches
18" - 16 sq inches
:P:ph34r::pardon::D
so would the port area be the same if i had 1 10" or 2 10"s? is it just based on box volume?
In Dash
Rear Flip Down
I put as much port as possible in (within reason) ... adjust the port length from there. My old box was 16 net cubes with 300" of port which is a bit much according to the standard but kicked ass playing the lows. This new box is 20 net with 200" of port due to space constraints, should be fine also.... Depends on the setup for sure. What these guys are telling you is right on target though... good place to start.
As for the last question, I like to use more port for more subs/larger boxes/bigger subs....
Port area FTW!
Check out StoneSounds to see my recent builds.Or look at the Flying White Facebook Page!
  • Who's Online   0 Members, 0 Anonymous, 2193 Guests (See full list)
