Like I said I will leave this to the subwoofer guys.
It might be time to get a beefier subwoofer.
I did just see your already useing a ported box.
Isobaric - Refers to the practice of coupling two drivers together to make them act as one.
"Giving up doesn't always mean you are weak; sometimes it means that you are strong enough to let go."
Insanity: doing the same thing over and over again and expecting different results.
The Destruction of a person builds character.
i try that but i lost 3db's
must not be 100% sealed becuase it should get louder not quieter(sp)
a guy with 3 jl 12w3 on a seald box was hitting a 141 on music.he only had a 1000watt jl amp.
3 12's vs your 1 15, same power.
Cone area FTW
i also say rebuild and do it ported. you'll get more output that way. the output you get is mostly what's in the install. so you could get way over your expectations with a ported box, or you might be less satisfied. but imo it's worth a try and definitely the cheaper way to go
Rebuild the box. It's all in the install.
Take my system for example. 4 15s on a 6500d. I'm only doing 146.7 on music, 30second average. I should be in the 50s with this setup, but my box is not exactly right (and soon to be rebuilt).
It takes more than just shoving a box in a vehicle, wiring it to an amp, to get loud on the meter. Research, built, test, tear down, rebuild, test, tear down, and so on until you get where you want.
And 135.6 on music is not a bad score at all, especially if your trunk car is of a large version (caddy, etc..). My team mate is doing 138.1 with one 12 on 2kw, so you're right in there.
Team Pinnacle / Team SouthEastSPL / Team SoundStream / Team GPI / GPI Sales Rep for Florida and Georgia
i was thinking the same thing at first i had 2 15 ssd with a t1k and i wasnt even breaking 140 my seats dont fold down
i went with a sealed box 2cub per driver braced i can do 140 pretty consistantly just play around with box and setup im sure you can get better results for cheaper than buying more subs
current set-up
kenwood ddx 712
clarion eq
focal 165 k2p front
focal 165v2 rear
2 re audio sexxx 12
us amps md3d
us amps md42
1 optima yellow top (rear)
1 xs power 5100r (front)
big 3 and 1 run 1/0 stinger wire
my build
my rebuild
