So I gotta make an underhood battery tray, so I made a mock up out of cardboard. What do I cover the cardboard with so resin and glass cloth don't stick to it? Aluminum Foil?
PTCary
2003 SMD PT Cruiser
2011 Honda CBR 250R
2010 Mazda 3i Sport
MY BUILD LOG
i usually do foil, and then duct tape and then spray it with a lubricant so its easier to remove
94 3000gt
18" Kicker Solo X
KX2500.1
2 KX350.4
8 JBL Coax Speakers
250A Mechman Alt
  • 2 months later...
Spray what with lubricant?
Just cover everything you don't want the glass to stick to in foil. (The more shiny side up) Then you can use a release agent, (wax) on the foil as well.
Then just lay a wet batch of resin, be quick and stipple the mat into that resin, then start building up layers as usual.
Only thing I wouldn't recommend is using the spray glue to get the first layer. It's always easier when building enclosures to start off by gluing the mat to the surface then coming in with resin, however on a project where you will be releasing the glass from the object you don't want to go that route. Just brush an even layer of resin and add the glass to it right away, and use the brush to stipple the glass down into the resin, and it will soak into the glass making a very good first layer.
MECP_SMALL.jpgCERTIFIED BITCHES!!!
Not being new at something doesn't mean anything. Just because a prostitute isn't new at what she does, doesn't change the fact that she still 'sucks'
Click to see my build!
Proud DC owner
even without a release agent, the foil usually peels off pretty easily as long as you put it down real smooth and theres no ridges to grab on, or seams for it to seep through. but a little bit of foil never really hurt
Team DC
