ptcary Posted July 14, 2008 Report Share Posted July 14, 2008 So I gotta make an underhood battery tray, so I made a mock up out of cardboard. What do I cover the cardboard with so resin and glass cloth don't stick to it? Aluminum Foil? PTCary 2003 SMD PT Cruiser 2011 Honda CBR 250R 2010 Mazda 3i Sport MY BUILD LOG Link to comment Share on other sites More sharing options...
jlgn_2000 Posted July 14, 2008 Report Share Posted July 14, 2008 i usually do foil, and then duct tape and then spray it with a lubricant so its easier to remove 94 3000gt 18" Kicker Solo X KX2500.1 2 KX350.4 8 JBL Coax Speakers 250A Mechman Alt Link to comment Share on other sites More sharing options...
Mesto Posted October 3, 2008 Report Share Posted October 3, 2008 i usually do foil, and then duct tape and then spray it with a lubricant so its easier to remove Spray what with lubricant? Link to comment Share on other sites More sharing options...
The Performer Posted October 3, 2008 Report Share Posted October 3, 2008 Just cover everything you don't want the glass to stick to in foil. (The more shiny side up) Then you can use a release agent, (wax) on the foil as well. Then just lay a wet batch of resin, be quick and stipple the mat into that resin, then start building up layers as usual. Only thing I wouldn't recommend is using the spray glue to get the first layer. It's always easier when building enclosures to start off by gluing the mat to the surface then coming in with resin, however on a project where you will be releasing the glass from the object you don't want to go that route. Just brush an even layer of resin and add the glass to it right away, and use the brush to stipple the glass down into the resin, and it will soak into the glass making a very good first layer. CERTIFIED BITCHES!!! Not being new at something doesn't mean anything. Just because a prostitute isn't new at what she does, doesn't change the fact that she still 'sucks' Click to see my build! Proud DC owner Link to comment Share on other sites More sharing options...
raytard Posted October 3, 2008 Report Share Posted October 3, 2008 even without a release agent, the foil usually peels off pretty easily as long as you put it down real smooth and theres no ridges to grab on, or seams for it to seep through. but a little bit of foil never really hurt Build: http://www.stevemeadedesigns.com/board/ind...hl=avalon+build monster/rockford/kicker/stinger cables, pioneer source, jbl highs/amps, kinetik/shuriken batts, iraggi alt, dei security, dc subs(atleast for now) Team DC Link to comment Share on other sites More sharing options...
