Sub Wiring Help Needed
Guest aseanj52
How many amps do you have? What kind of power do you have? Like in alts and batts? I ran my Memphis down at .5 ohm and it didn't get to hot, but i have good power to it. My friends ran his Hifonics at .5 and it almost melted with heat, he had bad power.
2 crunch 1500.1's stock 130 amo alt no aux. batteries.
hopefully soon i will be adding a kinetik 1400 and either a 2000 or a 2400. i already have preety bad voltage drop.
----reference's----
meade916
That amp is rated MAX power of 1500watts. Its only rated 750watts rms @ 1ohm so about 375ish @ 2ohm. You'll do best to just run the two amps on 4 subs.
thats wht i have now. each amp is putting out roughly 1200RMS. my step dad is a electrical engineer and he bench tested them. at 14.4 volts 1 made 146x and the other did 143x.
P 1500.1
1500W 1-Channel A/B Class Mono Amplifier
375W x 1-Ch @ 4-Ohms or
750W x 1-Ch @ 2-Ohms or
1500W x 1-Ch @ 1-Ohm Dynamic Music Watts
Includes Remote Mountable Bass Control
this is right off there site as well.
----reference's----
meade916
  • Who's Online   1 Member, 0 Anonymous, 1666 Guests (See full list)
