NAH916 Posted July 15, 2008 Report Posted July 15, 2008 i will probably stick with the 2 ohm load. i dont want to break my amps. You could always just run 2 of the 12's, and run it at 1ohm. Quote EG Limo Chrysler 300's Stretched Lambo Doors 20" Rims
Guest aseanj52 Posted July 15, 2008 Report Posted July 15, 2008 How many amps do you have? What kind of power do you have? Like in alts and batts? I ran my Memphis down at .5 ohm and it didn't get to hot, but i have good power to it. My friends ran his Hifonics at .5 and it almost melted with heat, he had bad power. Quote
reinke Posted July 15, 2008 Author Report Posted July 15, 2008 How many amps do you have? What kind of power do you have? Like in alts and batts? I ran my Memphis down at .5 ohm and it didn't get to hot, but i have good power to it. My friends ran his Hifonics at .5 and it almost melted with heat, he had bad power. 2 crunch 1500.1's stock 130 amo alt no aux. batteries. hopefully soon i will be adding a kinetik 1400 and either a 2000 or a 2400. i already have preety bad voltage drop. Quote ----reference's---- meade916
David Posted July 15, 2008 Report Posted July 15, 2008 if you have 2 amps, why not wire 2 subz per amp, that way each sub will see 750ish?? Quote
reinke Posted July 15, 2008 Author Report Posted July 15, 2008 if you have 2 amps, why not wire 2 subz per amp, that way each sub will see 750ish?? beacause i have 8 12's Quote ----reference's---- meade916
David Posted July 15, 2008 Report Posted July 15, 2008 well your first post said 4 so I went by that Quote
reinke Posted July 16, 2008 Author Report Posted July 16, 2008 well your first post said 4 so I went by that sorry about that. Quote ----reference's---- meade916
Derrick824 Posted July 16, 2008 Report Posted July 16, 2008 That amp is rated MAX power of 1500watts. Its only rated 750watts rms @ 1ohm so about 375ish @ 2ohm. You'll do best to just run the two amps on 4 subs. Quote
reinke Posted July 16, 2008 Author Report Posted July 16, 2008 That amp is rated MAX power of 1500watts. Its only rated 750watts rms @ 1ohm so about 375ish @ 2ohm. You'll do best to just run the two amps on 4 subs. thats wht i have now. each amp is putting out roughly 1200RMS. my step dad is a electrical engineer and he bench tested them. at 14.4 volts 1 made 146x and the other did 143x. P 1500.1 1500W 1-Channel A/B Class Mono Amplifier 375W x 1-Ch @ 4-Ohms or 750W x 1-Ch @ 2-Ohms or 1500W x 1-Ch @ 1-Ohm Dynamic Music Watts Includes Remote Mountable Bass Control this is right off there site as well. Quote ----reference's---- meade916
etaks_crew Posted July 16, 2008 Report Posted July 16, 2008 Why not get two more amps? So you can have all 8 running. Quote
