Okay ... in a nutshell here is my question.
For my new build I'm running 1/0 to the trunk from the starter battery, which goes to a distro block.
This distro block will put out 2 runs of 4 gauge - one for M&H amp one for the Sub amp.
Grounding each will be easy - find a place in the trunk. Remote and RCA are already ran (one of each) so I'm pretty sure I can split the Remote to both amps - but do I have to run a 2cd pair of RCA's from the HU or can those be split and still carry the same signal strength?
Thanks ... I realize this is stupid question but I'm still relatively new to all this
~Matthew
1998 Toyota Camry XLE V6 3L
(1) ScyTek Astra 4000RS-2W-1 2-Way Remote Start Alarm
with Shock and Proximity
(1) 20% Tint All Around (Gately Audio)
(1) 250 Amperage HO Alternator
(1) Big 3 Done In 1/0
(2) Kinetik HC2400 Power Cell
(1) Alpine IVA-D106 Receiver
(1) Peripheral Video Bypass Device
(4) Alpine SPS-17C2 Speakers
(1) Alpine KCE-422i iPod Control Interface
(4) Sheets Dynamat Extreme; for speakers
(1) 10 Square Feet Hushmat (Trunk & Rear Deck)
(4) DC Audio Level 4 15" D2 Subwoofer w/ Level 5 Coils
(1) Wall Built By David, Tuned to 32 Hz
(1) Rockford Fosgate T40001bd Amplifier
(1) Stinger 1/0 Wiring (2 runs of + 2 runs of -)
(1) Stinger Volt Meter
does your mids and highs amp have a pass through pre out? If so, that would be the way I would go, but I don't see why you could not just Y the rca's off to each amp, as long as the amps have internal crossovers to seperate the frequencies amplified. I could be wrong about the Y to both amps, so, if I am wrong, please someone send him in the right direction.
Loud as f*ck, and sounds good doing it.
Team built from here on out!!!!
BIG things to come.........
Missing link is the shite!!!
thanks for the advice!
bass amp SAE-1000D
M&H SAX-100.2 .....
let me know guys which is the best option
~Matthew
I guess that's the best option - Thanks
~Matthew
i take it you don't have a sub output on your h/u right?
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
No you're right .. I do ... at least I"m pretty sure I do .. Alpine IVA-D106 is a pretty good HU i'm guessing it does
i know what to do now, i think, thanks guys
~Matthew
well if so then run a set of RCAs to your high/mid amp and then run another set to you sub amp. that way at least you'd be able to use the subwoofer level control on the H/U.
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
Guest aseanj52
I usually try to stay away from splitting the signal for RCAs. i always figured it would half the voltage in them. But i finally had to when I wanted to run a 2 channel and a 4 channel amp. So i split them right before the 4 channel amp. Which didn't need any fading because it is pushing my 4 Pioneer Premier REV 6x9's in a row in the back. Didn't make to much of a difference.
  • Who's Online   0 Members, 0 Anonymous, 4261 Guests (See full list)
