1998 Camry Re-build (box Pics 9/27)
so today i returned the cap for an HC600 kinetik power cell. hpoefully that'll be bettere. quick wiring quesion - do i ground the amp to the battery or do i ground it to where the battery is gruonded (in trunk)
thanks, installing 2moor will get pics
~Matthew
1998 Toyota Camry XLE V6 3L
(1) ScyTek Astra 4000RS-2W-1 2-Way Remote Start Alarm
with Shock and Proximity
(1) 20% Tint All Around (Gately Audio)
(1) 250 Amperage HO Alternator
(1) Big 3 Done In 1/0
(2) Kinetik HC2400 Power Cell
(1) Alpine IVA-D106 Receiver
(1) Peripheral Video Bypass Device
(4) Alpine SPS-17C2 Speakers
(1) Alpine KCE-422i iPod Control Interface
(4) Sheets Dynamat Extreme; for speakers
(1) 10 Square Feet Hushmat (Trunk & Rear Deck)
(4) DC Audio Level 4 15" D2 Subwoofer w/ Level 5 Coils
(1) Wall Built By David, Tuned to 32 Hz
(1) Rockford Fosgate T40001bd Amplifier
(1) Stinger 1/0 Wiring (2 runs of + 2 runs of -)
(1) Stinger Volt Meter
just ground amp to battery, and have that amp grounded to either front battery, or to ground closly to the battery
or you can do both. have a ground running from the front battery to rear battery, amp grounded to rear battery and then rear battery grounded to frame.
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
i'm gonig to install it now. right now i dont have any negative runs from the front battery, so I will ground both the rear batt and the amp in the trunk (same spot) and see how that works
~Matthew
that should work just fine.
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
Ground the rear battery to frame and amps pos/neg to batter. You can use your back battery as a distro block too... Any other amps just power and neg to battery...
Passport Build Here
Alarm: Prestige APS997A 2-Way/Remote Start
HeadUnit: Pioneer DEH-P6000UB
Front Battery: Yellowtop Optima D34/78
Back Battery: 2x C&D Technologies High Rate Series UPS12-475FR 134AH
Subs: 2x DC Lv4XL 18's
Amps: 2x Sundown Saz1500's Strapped
Box: 12Cubes 33hz 185sqin Port(15.4sqin per cube)
Pillars: AudioBahn AS31Q
Front Doors: Clif Designs TX40.5
Back Doors: Clif Designs CD50.4C
Rear Speakers: Clif Designs TX46.5
Front/Rear Amp: Kicker ZX350.4
Back/Pillars Amp: Kicker ZX200.2(Looking for another zx350.4)
Electrical: 1/0 Scorpion Wire 2 Runs Pos and 2Runs Ground, Knu 1/0 Flex Running to Amps ect, Big 3, JL 8Ga For Speaker Wire, Knu Karma RCA's, Scorpion Volt Meter
Deadener: 100 sqft Sound Destroyer Mat And SECOND SKIN Damplifier Pro Door Pack
okay, i'll switch the ground of the amp from the frame to the battery. thanks for the heads up.
So far so good - at idle I get 12.8 as my lowest (full tilt) right now.
what are you guys thoughts of upgrading the under the hood battery to a deep cycle? needed, not needed?
I'll get pics soon
~Matthew
I'll get pics soon
Your electrical is only as strong as your weakest link... aka ... your stock battery...
Some people need a sympathetic pat... on the head...with my hammer
Scientia est Vox
DONT BE AFRAID TO USE THE SEARCH BUTTON!!!
SMD SUPER BUYER/SELLER
good point roscoe, thanks. i'll go ahead and order up a nice power master deep cycle from mechman in a week or 2 here
~Matthew
very nice setup, i was gonna buy a lvl 4 but i dont know if i have the cash to spend on an amp for it, might just go with some kickers...who knows
EDIT : wanna test a song for me? :give_rose: just heard it and it sounds like it will bump Hustlaz Ambition - Young Jeezy
thanks in advance
Who ever said nothing is impossible never tried to slam a revolving door.
  • Who's Online   0 Members, 1 Anonymous (See full list)
