Guest SyKo13 Posted September 17, 2006 Report Posted September 17, 2006 Sounds like hell lolSK ^-^ Quote
str86diesel Posted September 21, 2006 Report Posted September 21, 2006 Guys, sorry for the lack of response lately. Just got back from a long vacation. But I'm back and settled in, so I'll be more responsive now..Kev Quote 2k6 Dodge Ram 2500...CUMMINS POWERED - SOLD
Guest Brett32324 Posted November 20, 2006 Report Posted November 20, 2006 u know anything about fixin up cars. i busted sum shit up on mine by the axel in the back. wheel whobbles n squeaks n clincks. i should really get it fixed but i aint payin a shop. u know of the part i mite need? Quote
BURRITO Posted November 20, 2006 Report Posted November 20, 2006 u know anything about fixin up cars. i busted sum shit up on mine by the axel in the back. wheel whobbles n squeaks n clincks. i should really get it fixed but i aint payin a shop. u know of the part i mite need? year? make? model? rearend? please throw a bone... Quote Barretto MotorsportsTeam RFCTeam CHMTeam SMD "Blow Sand"Live Your Life Without Boundaries... http://www.jeffbarretto.acnrep.com/d_oppor...A=US_EN&BW=
str86diesel Posted November 20, 2006 Report Posted November 20, 2006 When it comes to mechanical items outside of the hood....Burrito's your man. Sounds like to me you need a new axle Quote 2k6 Dodge Ram 2500...CUMMINS POWERED - SOLD
polish1327 Posted December 3, 2006 Report Posted December 3, 2006 Gotta say Cummis muscle rules. My pops has a volvo semi with boss audio sound system it rocks, over 650hp with can't say how much torque except a Cat engine!! Quote Nismofreak School account.
RFkickin Posted December 5, 2006 Report Posted December 5, 2006 Hey man I got a 99 dodge ram 1500 5.9 2x4 i was wonder what i could do to make the trans shift out a little earlier because i could get a alot more speed faster if it wasnt tryin to redline ever gear and possible some cheap HP upgrades Thanks bro Quote
ChevyBoy Posted December 5, 2006 Report Posted December 5, 2006 Hey man I got a 99 dodge ram 1500 5.9 2x4 i was wonder what i could do to make the trans shift out a little earlier because i could get a alot more speed faster if it wasnt tryin to redline ever gear and possible some cheap HP upgrades Thanks bro http://www.superchips.com/product.phtml?p=...mmk=830&msg=%2B Quote
str86diesel Posted December 5, 2006 Report Posted December 5, 2006 RFkickin - First off, I gotta ask. If you go out to the flattest, straightest road you can find and from a dead stop, put the hammer down. I mean put your foot through the floor. What are your shift points for every single gear? Exluding final drive? I'm guessing you have a 4 speed (with OD) 42re trans. Can you do two runs for me. First, lockout od, what are your shift points for: 1-2= 2-3= 3rd-lockup= Then with OD engaged, what is your 1-2= 2-3= 3-lockup= unlock-4= 4-lockup= The easiest way to adjust shift points is by doing the following. When you pop your hood, you'll have a roundish looking plastic box with 2-3 plastic rivets, this assembly will be connected to the throttle body assembly (mine was on the driver side). When you pull the cover off of this plastic box, there will be a cable inside of it, with a retaining clip on it. Before you do ANYTHING, mark where the cable is connected!! This cable is actually how you adjust your shift points (its called a kickdown cable, or also called a throttle valve cable). I'll see if I can't get you a picture of it, plus some info on which way the cable goes. I'm about 98% positive, that if you pull the cable out, it will increase the rpm of your shift point. Which means in your case, you'd want to push the cable in. But for the case of speed, you want your shift point before redline and right at the point where your power starts to hit the peak of the power band. Kev EDIT: I went to go take a pic for you, spacing that I just swapped out for a manual, so I can't get you a pic without visiting a dealer. Ok, I just flipped open my service manual, if you have a manual its on page 21-288 and it is as I thought, as you pull the cable, your shift points will increase in rpms, but only adjust 1mm at a time (Yes, I am serious, 1mm at a time). PM me if you want me to scan some prints from my service manual for you. Kev Quote 2k6 Dodge Ram 2500...CUMMINS POWERED - SOLD
BURRITO Posted December 5, 2006 Report Posted December 5, 2006 :^ hey kev, you da man! Quote Barretto MotorsportsTeam RFCTeam CHMTeam SMD "Blow Sand"Live Your Life Without Boundaries... http://www.jeffbarretto.acnrep.com/d_oppor...A=US_EN&BW=
