I owned a car audio shop for about 10 years, but I closed down about 6 years ago. All of the sub boxes that I built I used wood screws and liquid nails or wood glue. I have seen a few boxes on here that seem to be held together with just wood glue and no screws. Will a sub box hold up to the pressure if you dont use wood screws to anchor it down? Or is everyone using wood screws and I just cant tell from the pics. :pardon:
n2caraudio.com
the glue holds the box together
the screws are there to keep the two pieces of mdf/birch held together while the glue adheres the two pieces together.
2015 Honda Civic LX 4dr | 110k miles | Stock
1996 GMC Yukon SLT 4dr 4wd | 260k miles | JVC Head-unit
Posted (edited)
I always used the wood glue and liquid nails to form a tight seal more than rely on it for strength.
I actually started out using clear silicon till I found out the fumes can errode the surround on the subs.
Edited by sonic purity
n2caraudio.com
i nail my boxs together, i dont use woodscrews cause i dont like em, im better with a brad nailer than i am a screw driver on buildin boxs, i use 1&1/2-3/4 nails to put it together with wood glue and my box is still together and i pound on it everyday, i aint used a screw sence the 90's, now i dont hate usein screws to build boxs, but i have better luck with nails tho, and i always use burch plywood cause somehow burch has a good resonance like when they make instruments with it, but anyways i use cylicone cauk in the seams, woodglue in the joints and brad nails to put together, but thats just me
wood glue and nails, usually about 16g brads, or 18g and screws, but I only use a few screws per board, the rest would be nails, seal the inside with anything -Ive used silicone for years, it only effects surrounds that use Toluene based rubber glues, and that is only if the sub is mounted right away, and the fumes stay trapped in the box
The all edged get routed flat for professional look, then rounded
  • Who's Online   0 Members, 0 Anonymous, 780 Guests (See full list)
