just looking for a ideas i have us amps 400 on two fi ssd 12's and i have already done the wire upgrades on the engine, have a second battery in the trunk (red top) and have 0 ga running to a distribution block where it seperates the power wire to my highs amp and the lows amp. now heres where i'm looking for ideas. on the us amps it takes three runs of 8ga wire each for ground and pos. if i already have a distro block with 0 ga running to it and the three 8ga to the amp should i leave it or should i increase the size of the 8ga wire? you guys think that would make any diffrerence?
Guest aseanj52
What you should do is run a power wire from you battery for each amp. That would help the most.
Which is what should be done anyway.
And redtops don't really provide much power like a powermaster/kinetik/stinger battery do.
Edited by wL<3bass
My YouTube Videos
My Fiberglass A-Pillar Build
My feedback/references...
yeah but i already had the red top from another car where i had red upfront yellow in the back. as for the wires you saying i should just do the three runs of 8ga straight from the battery?
Yup and get another redtop if necessary.
My YouTube Videos
Guest aseanj52
Well, i would use "At Least" 4 awg into the bass amps. And probably 4 awg into the highs amp to. Just to help power flow better.
More power usually = less clipping.
hmm.. yes this makes sense. think i'll do that this weekend, thanks folks.
Guest aseanj52
Make sure to put the right size fuse on each run to the back. What did you have on the 0/1?
  • Who's Online   0 Members, 0 Anonymous, 741 Guests (See full list)
