I installed my MTX 7500 15 dual voice coil sub. and other mtx 7801... i only had one amp hooked up (only 1 was running about 500 watts to the sub..the other just waiting for the other sub) so i had the both of them in there and my mtx thunder 302 2 channel amp.. they were just connected to the headunit's remote wire.. no relay or anything.. i went down the road in my neighborhood and was testing it out.. first the front speakers kept making a snapping noise then the back speakers.. which are hooked up to the 2 channel amp kept cutting out when the bass hit. then everything just shut off. headunit speakers amps..everything.. car ran fine.. what in the fuck could be the damn problem? i am pissed as fuck right now. i need help!! i think my damn headunit is blown, but why did the speakers keep cutting out when the bass hit?  PLEASE REPLY!!!
18's in a wall to come....Its not all about the posts....check the member #...
If there was music playing, yourh/u isn't blown
Your amp is pulling power that your battery doesn't have
nah.. it WAS playing music.. then EVERYTHING shut off after a little bit.. i really think its the headunit b/c it wont turn  on anymore... so im getting a new one very soon.
nope. its not the battery. im adding another soon anyway. either a kinetik or a redtop.. ill do the redtop as the starter battery and move my yellowtop to the back of the car, but as i said my headunit will not turn back on at all.. it has to be bad, car starts fine so its not the battery but i will need to get an extra battery for the trunk to get some better current and such. will be buying soon.
I have said before that turning on one amp with your H/U is fine. But the minute you upgrade to 2 or more amps...I strongly recommend a relay. I am guessing that the turn-on circuit in your H/U is blown because keeping the amps on was too much of a current draw.
do you have info on what kind of relay to add to turn on 2 amps?? i am ordering a PPI a200.2 amp tomorrow and wanna know how to use a relay to turn 2 amps on properly
new setup in the works
Iam with Dale on that one. Bypass the remote, hook it up to ignition, then use a relay, if that doesnt work, THEN its the deck tweekin out.
the relay will look like this and it will come with very simple instructions and a 30 amp relay will do all you will need is a few female quick connects ends as shown in the pic and a few feet of some 16-12ga wire for larger amps i would use a bigger ga wiref_25446042i_ce83m_434b33ad.jpg
Where is the relay in the fuse box?
there isnt any. theres fuses in there though. you have to go out and buy a relay.
check the fuse on the back of the head unit, and the one if your fuse box.
  • Who's Online   0 Members, 0 Anonymous, 801 Guests (See full list)
