251customs Posted July 31, 2008 Report Posted July 31, 2008 right now my setup is 4 btl 18s old ones dual 1s i have a powerbass asa 1000.1 on each woofer at .5 ohms i have 4 kenetiks 2400s and the power draw is crazy i guess cause the amps are at .5 ohms. but my question is i have 4 more pb 1000.1s that i can use and strap 2 amps on each woofer at 2 ohms would that bring my power draw down since im increasing the ohms that they are playing at or will i be in the same boat since im doubling the amps and which combo would be louder....electrical system.... 240 atl (nations alternator) 4 runs of 0 awg to the back batterys two red tops under hood and the big three is done i can hit 9 volts at idle at about 2 min into a song at full tilt maybe this is normal???? let me know oh yeah and i have a maxxlink i can use if we go with the 8 1000.1s.... its all in a 02 dodge ram in the camper shell with the window blowthrough 02 dodge ram quad cab 4.7 pioneer 9800bt pioneer 5700 dvd(yes 2 headunits 5700 for dvd only) 1 re xxx 15 (new style in center console) 4 18" fi btls in snugtop 12 mb quart 6.5s original ones not maxxsonics (kicks, 3 in each front door 2 in each back door) quart 4" dash sp 2 soundstream xxx6500s 1 pd asa1000.1 for the xxx15 4 pb asa600.4 highs 4 7" screens 1 15" flipdown 2 red tops 16 g31 yellow tops playstation 2 4 8x11 p.a. horns under truck (music plays through them) db 80.2 for horns 2 underglow kits (1 flex kit in fenderwells) 24" martin bros vampires
Chode69 Posted July 31, 2008 Report Posted July 31, 2008 honestly that sounds like a bad headache haha all them amps. why not step up to (2) 4k amps. NoFearX18 said: Nick will bang just about anything.....LMAO....pun intended On 4/13/2010 at 9:51 AM, meade916 said: i was like DAMN, Chode is hardcore! he makes james look like a friendly person LOL! trainman0978 said: I dont know who is worse with the buttholes Chode or Big P... Team Deadly Hertz / Team DC Audio / Team XS Power 2010 DC AUDIO MEMBER OF THE YEAR!!! DuckretaryFEAR THE DUCK Durangho Chodes Blowthrough Build Youtube vids Muh Wife Need DC Audio? Hit me up for pricing!!!
251customs Posted July 31, 2008 Author Report Posted July 31, 2008 honestly that sounds like a bad headache haha all them amps. why not step up to (2) 4k amps. i just already have a bunch oh these amps plus it has the wow factor when i open the back of the truck and all u see is amps 02 dodge ram quad cab 4.7 pioneer 9800bt pioneer 5700 dvd(yes 2 headunits 5700 for dvd only) 1 re xxx 15 (new style in center console) 4 18" fi btls in snugtop 12 mb quart 6.5s original ones not maxxsonics (kicks, 3 in each front door 2 in each back door) quart 4" dash sp 2 soundstream xxx6500s 1 pd asa1000.1 for the xxx15 4 pb asa600.4 highs 4 7" screens 1 15" flipdown 2 red tops 16 g31 yellow tops playstation 2 4 8x11 p.a. horns under truck (music plays through them) db 80.2 for horns 2 underglow kits (1 flex kit in fenderwells) 24" martin bros vampires
dmanson Posted July 31, 2008 Report Posted July 31, 2008 right now my setup is 4 btl 18s old ones dual 1s i have a powerbass asa 1000.1 on each woofer at .5 ohms i have 4 kenetiks 2400s and the power draw is crazy i guess cause the amps are at .5 ohms. but my question is i have 4 more pb 1000.1s that i can use and strap 2 amps on each woofer at 2 ohms would that bring my power draw down since im increasing the ohms that they are playing at or will i be in the same boat since im doubling the amps and which combo would be louder....electrical system.... 240 atl (nations alternator) 4 runs of 0 awg to the back batterys two red tops under hood and the big three is done i can hit 9 volts at idle at about 2 min into a song at full tilt maybe this is normal???? let me know oh yeah and i have a maxxlink i can use if we go with the 8 1000.1s.... its all in a 02 dodge ram in the camper shell with the window blowthrough i'd say a good HO alt or dual HO alt would solve this voltage drop 2-DC 15XLM2 D.7s 1-DC 5K amp (1) XS Power D6500(UNDERHOOD) and (1) XS3000(REAR) 3 runs 1/0ga for power and 2 runs of 1/0ga for negative. (2)-RFT165s components, ...... 4 separate 1 inch tweetersRF T600-2(fronts) Punch 450.4(rear) Audiocontrol 3.1. DC power 260amp alternator w/MLA Module
251customs Posted August 1, 2008 Author Report Posted August 1, 2008 i'd say a good HO alt or dual HO alt would solve this voltage drop the 02 and up dodge rams alternators are regulated through the ecu so my alternator options are very limited (even for Dom) 02 dodge ram quad cab 4.7 pioneer 9800bt pioneer 5700 dvd(yes 2 headunits 5700 for dvd only) 1 re xxx 15 (new style in center console) 4 18" fi btls in snugtop 12 mb quart 6.5s original ones not maxxsonics (kicks, 3 in each front door 2 in each back door) quart 4" dash sp 2 soundstream xxx6500s 1 pd asa1000.1 for the xxx15 4 pb asa600.4 highs 4 7" screens 1 15" flipdown 2 red tops 16 g31 yellow tops playstation 2 4 8x11 p.a. horns under truck (music plays through them) db 80.2 for horns 2 underglow kits (1 flex kit in fenderwells) 24" martin bros vampires
David Posted August 1, 2008 Report Posted August 1, 2008 there only limited because you havent done your homework. search MLA module on this forum, then comeback and tip me 20 bucks for the help
Boon Posted August 1, 2008 Report Posted August 1, 2008 8 amps at 1 ohm each will give you the same current draw as 4 amps at 0.5 ohm, theoretically... obviously you'll draw more current though with 8 amps If you're getting drops that bad you really need to sort your electrical... 9v after 2 minutes is crazy, I can run 4.5kw for like 10 mins off a single 105Ah battery... 10.x volts fo' life!
251customs Posted August 1, 2008 Author Report Posted August 1, 2008 there only limited because you havent done your homework.search MLA module on this forum, then comeback and tip me 20 bucks for the help ive done my homework i called them and they dont make one for my truck and only ford or chevy not my application I even talked to iraggi and he said that he could come up with something to isolate the factory dodge atl and run an extra chevy alt for the back battery bank but he has no brackets for this applications either. but i do thank you for your thoughts do your homework nextime 02 dodge ram quad cab 4.7 pioneer 9800bt pioneer 5700 dvd(yes 2 headunits 5700 for dvd only) 1 re xxx 15 (new style in center console) 4 18" fi btls in snugtop 12 mb quart 6.5s original ones not maxxsonics (kicks, 3 in each front door 2 in each back door) quart 4" dash sp 2 soundstream xxx6500s 1 pd asa1000.1 for the xxx15 4 pb asa600.4 highs 4 7" screens 1 15" flipdown 2 red tops 16 g31 yellow tops playstation 2 4 8x11 p.a. horns under truck (music plays through them) db 80.2 for horns 2 underglow kits (1 flex kit in fenderwells) 24" martin bros vampires
