Battery Tip
Guest MegaloManiac
isnt there a .2v loss or something like that when using an isolator???
i dunno if this applies to a single alt setup or not but i was told by mr.iraggi himself NOT to use any isolators.
Guest MegaloManiac
I think that is if you have just 1 battery, I'm not sure i'll look into it
i heard the same thing about isolators also ...... voltage drop that is. anyways i'm thinking about doing a dual battery tray under the hood with two of those dual purpose yellowtops.
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
the only time you will need an isolator is when you are running different batteries in the rear than the one upfront (ie... different brand name, different cranking and cold cranking amps) this this keeps one battery from over charging. but if they are all the same batteries then yes there is no need to run a isolator. I have been running Isolators for a while now and i don't have a complaint about them
Guest MegaloManiac
i guess thatl work to. i havent thought about that lol
  • Who's Online   0 Members, 0 Anonymous, 4546 Guests (See full list)
