ahhhhh gotcha thanks guys
~Matthew
1998 Toyota Camry XLE V6 3L
(1) ScyTek Astra 4000RS-2W-1 2-Way Remote Start Alarm
with Shock and Proximity
(1) 20% Tint All Around (Gately Audio)
(1) 250 Amperage HO Alternator
(1) Big 3 Done In 1/0
(2) Kinetik HC2400 Power Cell
(1) Alpine IVA-D106 Receiver
(1) Peripheral Video Bypass Device
(4) Alpine SPS-17C2 Speakers
(1) Alpine KCE-422i iPod Control Interface
(4) Sheets Dynamat Extreme; for speakers
(1) 10 Square Feet Hushmat (Trunk & Rear Deck)
(4) DC Audio Level 4 15" D2 Subwoofer w/ Level 5 Coils
(1) Wall Built By David, Tuned to 32 Hz
(1) Rockford Fosgate T40001bd Amplifier
(1) Stinger 1/0 Wiring (2 runs of + 2 runs of -)
(1) Stinger Volt Meter
i ran mine to the 2nd battery. gets a better reading.
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
i am trying to read the voltage at the amp roscoe so thanks you helped alot. I am going to run it how you said thanks :)
**New setup in the works** Shocker sigs ftw!
*Breakin Glass and Kickin Ass*
Team SBC
Team Full Force
Refs
SMD-derrick, Bangin Explorer, Exposport, Bass 14
CA-connersdad19 x2, Ridnclean, Deafdreamz, nismos14
cac.org-Spl Guru, Andrew, dblover, lunari
from the system? same way at the amp or the battery closest to the amps. If you measure from the front you will most likely get a false reading do to the alt being right there.
Okay so just wiring the voltage meter to the amp(s) will give you the most accurate way to monitor your voltage to the amp(s)?
Derp.
i had my volt meter wired to my H/U ....... sucked balls man because my voltage was jumping up and down something terrible so i ran my + back to my 2nd battery and my reading is more accurate and doesn't jump up and down now.
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
