Whats the best/easiest way to install a digital voltage meter ?
**New setup in the works** Shocker sigs ftw!
*Breakin Glass and Kickin Ass*
Team SBC
Team Full Force
Refs
SMD-derrick, Bangin Explorer, Exposport, Bass 14
CA-connersdad19 x2, Ridnclean, Deafdreamz, nismos14
cac.org-Spl Guru, Andrew, dblover, lunari
wire it straight to the/a battery. take some velcro or something and stick it w/e you want :). quick and dirty
that'd work but then it would always be on ..... if i were you i'd just follow the instructions!! i think they're usually power ground and +switched?
just tap into your HU wiring harness
~Matthew
1998 Toyota Camry XLE V6 3L
(1) ScyTek Astra 4000RS-2W-1 2-Way Remote Start Alarm
with Shock and Proximity
(1) 20% Tint All Around (Gately Audio)
(1) 250 Amperage HO Alternator
(1) Big 3 Done In 1/0
(2) Kinetik HC2400 Power Cell
(1) Alpine IVA-D106 Receiver
(1) Peripheral Video Bypass Device
(4) Alpine SPS-17C2 Speakers
(1) Alpine KCE-422i iPod Control Interface
(4) Sheets Dynamat Extreme; for speakers
(1) 10 Square Feet Hushmat (Trunk & Rear Deck)
(4) DC Audio Level 4 15" D2 Subwoofer w/ Level 5 Coils
(1) Wall Built By David, Tuned to 32 Hz
(1) Rockford Fosgate T40001bd Amplifier
(1) Stinger 1/0 Wiring (2 runs of + 2 runs of -)
(1) Stinger Volt Meter
What are you trying to monitor, voltage at the amp? battery? head unit? power seats? IMO voltage at the amps is more important than any so I would run a wire to the amp for each wire on the meter. + to the + of the amp, - to the - of the amp and switched to the remote turn on.
Some people need a sympathetic pat... on the head...with my hammer
Scientia est Vox
DONT BE AFRAID TO USE THE SEARCH BUTTON!!!
SMD SUPER BUYER/SELLER
would that cause the wires on the meter to overheat fromt oo much current or no?
~Matthew
So this is the best way to monitor your vehicles voltage for drops and such?
Derp.
from the system? same way at the amp or the battery closest to the amps. If you measure from the front you will most likely get a false reading do to the alt being right there.
Scientia est Vox
the wire is only going to carry the ammount of current the accessory needs.
DC.jpgDC POWER
  • Who's Online   0 Members, 0 Anonymous, 615 Guests (See full list)
