i know nothing of those....
haven't had a chance to play with em....
i've heard some good things about em though.... don't take my word for it though.
well if u go to http://www.audioque.com/aq/AQ3500D.htm it has the power outputs for a amp. is it 3500max @ 1 ohm or 3500rms @ 1 ohm?
Ride: 2001 BMW325ci
Headunit: Alpine ida-x305
High/mid: stock harmon/kardon everything: 6 tweets, 1 set of 6.5" and 1 set of 6x9, 500rms total
Sub: (1) 15" DC Audio Level 5 D2 ohm
Amp for sub: MTX 4001d
Box: custom built 3.5 cuft ported
Power: 220amp alt from ohio gen, 2 kinetik 2400s in back
(Armoredhaulin @ May 29 2009, 08:34 AM)
Why waste your time with this tool? His system sucks, that's all there really is to it. My toilet puts out more low end and flex than that thing!
3500w rms @ 1 ohm
so with 2 Audioque 2200D thatd be 4400 rms which would be enough to run 2 15" fi btl subs, which r rated at 2000rms each. correct?
also, if i could get the Audioque 3500D to put out 1 ohm Power @ 18V @ 10% THD =6,500W x 1 thatd be 6500rms? which would be enough to power 2 pioneer subs that handle 3000 rms each?
Ride: 2001 BMW325ci
3500w rms @ 1 ohm
also, do u know if those amps r 2 channel? so i could power both subs off the one amp?
Ride: 2001 BMW325ci
single channel.
you can run multiple subs off of an amp, as long as you make sure the impendance isn't lower than the amp's reccomended (1ohm).
single channel.
so even tho its not a 2 channel the Audioque 3500D could power both subs? r u talkin about the impendance on the sub?
Ride: 2001 BMW325ci
single channel.
is that possible to get ("1 ohm Power @ 18V @ 10% THD =6,500W x 1") 6500 rms from a 3500?
Ride: 2001 BMW325ci
dont make it to difficult on yourself
just do 1 amp, a pretty big amp, not huge
you obviously havent got years of experience in this, so even if you double the power, and cone area you currently have now, it will be night and day difference between what you have now and will have
I bet aything 2 BTLs/BLs 15s over t 2-12s you have, and the amps you have will shit all over them
I dont think just jumping to something so drasticly larger/powerful than you have now is the right thing to do
I mean, your sealed n,so that eqauls big loss in SPL
once you go to ported alone, you will see major gains over sealed
then real amps, not audobahn amps, another big gain
real power supply, bats not caps
big power wires, MLA module, upgrade the alt
Audiobahn 2000watts equals 750-1000 watts of RF Power, Sundown, Audioque power- QUALITY products make a huge difference
yea sry i am new at this. i just want to get a sick system now then hav to spend more money later.
so u think i should get a ported box?
the impedance on the pioneer Premier TS-W8102SPL subs i want is 2 ohms. would the Audioque 3500D still be able to work at 1 ohm Power @ 18V @ 10% THD so i can get the 6500 i need?
Ride: 2001 BMW325ci
and since i have a nice car, u think just batteries would be enough to power the amp witout a bigger alt?
and if i got 2 btls i'd get 2 Audioque 2200D so i'd hav to deal wit 2 amps to wire. and dont hav T2 12"s, i hav 2 audiobahns 12".
Ride: 2001 BMW325ci
  • Who's Online   1 Member, 0 Anonymous, 2817 Guests (See full list)
