theterminator Posted August 9, 2008 Report Posted August 9, 2008 so im running a 1000w rms. I have a HC800 as my primary battery. I have about 14ft of 4ga (kicker wire)going to the amp. I was testing the voltage at the battery and the with the volume all the way up my volts never dropped under 13v. Then i tested at the amp. And the volts dropped as low as 12.3v. Is this normal or can i fix this problem?
wL<3bass Posted August 9, 2008 Report Posted August 9, 2008 so im running a 1000w rms. I have a HC800 as my primary battery. I have about 14ft of 4ga (kicker wire)going to the amp. I was testing the voltage at the battery and the with the volume all the way up my volts never dropped under 13v. Then i tested at the amp. And the volts dropped as low as 12.3v. Is this normal or can i fix this problem? less wire.... the closer a battery is to an amp the better. Vehicle: 1997 S10 Blazer 4dr 4X4 Exterior: Rear End Bagged, Black Grill, Lifted 2" Amplifiers: Rockford Fosgate T8004 & T10001bd Batteries: 2 Stinger SPV35, Kinetik HC2400 Electrical: Big 3, DC Power 290amp Alternator w/ MLA at 15.5v Enclosure: 4.2 ft³ @ 33Hz 84sq.in. of port (20sq.in. per cube) Headunit: Eclipse CD3200 w/ 80G iPod Mids/Highs: Rockford T152s (a-pillars), Rockford T162s (doors) Subwoofers: 1 15" Fi BL Fully Loaded Wire: All 1/0g Kicker Hyperflex My YouTube Videos My Fiberglass A-Pillar Build My "Seamless" Looking Box Build My DD1508 T-Line Bandpass Build "Seamless" w/ Acrylic Windows (for '05 TrailBlazer) My Stealth 8" Fiberglass Build (for '05 TrailBlazer) My Build For A Friend's '08 Cobalt 15" BL Sealed Off From The Trunk My feedback/references...
IH8PunkRok Posted August 9, 2008 Report Posted August 9, 2008 less wire.... the closer a battery is to an amp the better. bigger wire will also increase voltage to the amp from the battery a second battery is always sumthin worth doin -Matt2005 Dodge Magnum RTJVC KD-AVX1 2 PPI S580.2 Obsidian Audio ST1 Horn Tweeters PRV 8MB450s Audio Legion 3500.1D 2 RE MT 18s 360 ah LiFePO4 BatterySHCA 2/0 155.2 @ 29 hzKicker CVR 15's buildDD 3512e buildMini T-Line Build(6) 8s BuildNightshade 15s Wall BuildMagnum AB XFL 12s BuildNewest Magnum Build
theterminator Posted August 9, 2008 Author Report Posted August 9, 2008 So you think running 0ga to another HC800 in the trunk and then to the amp will fix this problem.
Dale Posted August 9, 2008 Report Posted August 9, 2008 So you think running 0ga to another HC800 in the trunk and then to the amp will fix this problem. It'll certainly help. That 14ft wire is what's killing you...the resistance is too high.
missinglink Posted August 9, 2008 Report Posted August 9, 2008 So you think running 0ga to another HC800 in the trunk and then to the amp will fix this problem. Nowing what kind of car you need the advice on will help us too. If you are adding a batt try one a little bigger than a HC800 like the 1400 or their 1800 as your main if you have room. If not in back would be fine also. As for wire if you are gonna use 1/0 gauge from your battery to your amps you should keep it the same size from your alternator to your battery as well. I use same size wire for power and ground keeps things easy I feel. As for the voltage drop pending on the vehicle we can help you out as well . Thanks,MLA missinglinkaudio The United States Marine Corps. When it absolutely, positively has to be destroyed overnight - even if "it" belongs to the base commander...
theterminator Posted August 9, 2008 Author Report Posted August 9, 2008 Nowing what kind of car you need the advice on will help us too. If you are adding a batt try one a little bigger than a HC800 like the 1400 or their 1800 as your main if you have room. If not in back would be fine also. As for wire if you are gonna use 1/0 gauge from your battery to your amps you should keep it the same size from your alternator to your battery as well. I use same size wire for power and ground keeps things easy I feel. As for the voltage drop pending on the vehicle we can help you out as well .Thanks,MLA Its in a Mazda 6 V6 with stock alt. I have upgraded the big 3 already with 0 ga wire. I was gonna put a 1400 under the hood but it was too big so i had to settle for the 800.
missinglink Posted August 9, 2008 Report Posted August 9, 2008 I would add a 1400 or an 1800 in the back then. Should help keep things up with the extra storage. If you bench charge the battery before you install it your alt will not have to work as hard to get it charged , and will reduce the initial strain from the alt to the new batt. MLA missinglinkaudio The United States Marine Corps. When it absolutely, positively has to be destroyed overnight - even if "it" belongs to the base commander...
