Gearstix Posted August 11, 2008 Report Posted August 11, 2008 I have a 1994 GMC Sonoma. If I remeber right my alt is 100 amps, not 100% sure (2.2L 4 cylinder) I am wondering if there are any 140-150 amp alternators that are stock on other vehicles and compatible with my truck. I'm trying to find an alternator on a budget. I might run one or two alternators depending on how much wattage I'm gunna run, as it looks right now, it'll only be around 1kW-1.5kW, but I would like to have some headroom. However, I might be doing a engine swap, taking out my four cylinder and putting in a small block chevrolet.. I'd like to have an alternator that I could use on either or. Also if I can find an engine, it'll be carbureted. My truck is OBDI. 2005 Blazer Build... Mach 5 SPL-12s, Audiopipe AP3000.1D..
MECHMAN Posted August 11, 2008 Report Posted August 11, 2008 I have a 1994 GMC Sonoma. If I remeber right my alt is 100 amps, not 100% sure (2.2L 4 cylinder) I am wondering if there are any 140-150 amp alternators that are stock on other vehicles and compatible with my truck.I'm trying to find an alternator on a budget. I might run one or two alternators depending on how much wattage I'm gunna run, as it looks right now, it'll only be around 1kW-1.5kW, but I would like to have some headroom. However, I might be doing a engine swap, taking out my four cylinder and putting in a small block chevrolet.. I'd like to have an alternator that I could use on either or. Also if I can find an engine, it'll be carbureted. My truck is OBDI. You won't find a stock alt over 140 amps that bolts in place of your unit. You could use a 140 amp stock CS144 if you but a V8 in there, but you will still have to tweak the V8 alternator bracket to make it fit, and you would still need an adapter plug. 1-888-MECHMAN www.Mechman.com [email protected]
Gearstix Posted August 11, 2008 Author Report Posted August 11, 2008 You won't find a stock alt over 140 amps that bolts in place of your unit. You could use a 140 amp stock CS144 if you but a V8 in there, but you will still have to tweak the V8 alternator bracket to make it fit, and you would still need an adapter plug. I can deal with fabbing up brackets and stuff. 2005 Blazer Build... Mach 5 SPL-12s, Audiopipe AP3000.1D..
MECHMAN Posted August 11, 2008 Report Posted August 11, 2008 I can deal with fabbing up brackets and stuff. Then get one off of a 95 Impala SS. It will be 140 amps. 1-888-MECHMAN www.Mechman.com [email protected]
MECHMAN Posted August 11, 2008 Report Posted August 11, 2008 . double post. 1-888-MECHMAN www.Mechman.com [email protected]
wL<3bass Posted August 11, 2008 Report Posted August 11, 2008 This guy is selling one really cheap $215 shipped for a 250 amp alt by EA Vehicle: 1997 S10 Blazer 4dr 4X4 Exterior: Rear End Bagged, Black Grill, Lifted 2" Amplifiers: Rockford Fosgate T8004 & T10001bd Batteries: 2 Stinger SPV35, Kinetik HC2400 Electrical: Big 3, DC Power 290amp Alternator w/ MLA at 15.5v Enclosure: 4.2 ft³ @ 33Hz 84sq.in. of port (20sq.in. per cube) Headunit: Eclipse CD3200 w/ 80G iPod Mids/Highs: Rockford T152s (a-pillars), Rockford T162s (doors) Subwoofers: 1 15" Fi BL Fully Loaded Wire: All 1/0g Kicker Hyperflex My YouTube Videos My Fiberglass A-Pillar Build My "Seamless" Looking Box Build My DD1508 T-Line Bandpass Build "Seamless" w/ Acrylic Windows (for '05 TrailBlazer) My Stealth 8" Fiberglass Build (for '05 TrailBlazer) My Build For A Friend's '08 Cobalt 15" BL Sealed Off From The Trunk My feedback/references...
