so the other day i was bumpin to some breaking benjamin and all of a sudden the sub stops bumping there was no stink no noise or anything just stopped working. the amp is still working and today i checked all the wiring in the sub i checked all the wires with a ghetto multi tester that i couldnt understand so tonight im going to get a new multi meter to really test it
is there anything else i should check if the wiring from the amp to the sub is all okay
all the equipment i have is in the sig
thanks
If you got a 9 or 12 volt electric drill take the batt and touch on pos of the speaker to one of the batt prongs and then the neg of the speaker to the other prong of the drill batt if the speaker don't pop don't worrie its not.a bad pop if it don't pop your speaker is a gonner or your a tinsel lead broke or you don't know how to wire
aight ill try those things but i dont have a lot of time during the week because im in band and we have practice 9hrs a day(4 in the moring 5 at the night)
so i may try that tomorrow during our small break dont have enough time today
Pretty simple, Get a DMM, and turn the system on. Check the voltage coming out of the amp. If there is any voltage, the amp is fine. Then check the ohm load out of the speaker(s). on of the 2 won't have a reading.
816-591-6592
www.kcrimshop.com
well easy enough my bro came home so i just tested my sub on his system and when i plugged the wires in i got nothing out of the sub
but i failed to mention that my bro took my car one day and turn the system a lil too loud and when i got in my car later i smelt something really bad (assuming a burned coil)
so i assuming something came undone or something in the sub crapped out because of it
Bro owes......
nah i dont care because i have a best buy warranty ftmfw so i took it back and now i got my type r back since i previously owned one but blew it because i had bass boost up ftl but i got it back and it cost me NOTHING
so i recommend buying a sub from best buy if you dont plan on changing brands and think you might blow it because all you do it take it back and get a new one for free
  • Who's Online   0 Members, 0 Anonymous, 2415 Guests (See full list)
