if you go into the "ELECTRICAL" section on here and look under "IMPORTANT TOPIC .......WIRE/FUSE guide" and you'll see the chart for the different size power wires and then you scroll down and you'll find the speaker wire sizes. so yes there is a chart for this.
NVM! Damn just seen it!
Thanks tons man, I must have not even seen that earlier! :D
Edited by The Performer
MECP_SMALL.jpgCERTIFIED BITCHES!!!
Not being new at something doesn't mean anything. Just because a prostitute isn't new at what she does, doesn't change the fact that she still 'sucks'
Click to see my build!
Proud DC owner
Here is a quote from that chart
12 gauge: ~21.8 amperes
8 ohms - <3800 watts
6 ohms - <2850 watts
4 ohms - <1900 watts
3 ohms - <1425 watts
2 ohms - <950 watts
1 ohm - <475 watts
Im running 2 18" BL's D1's wired to 1 OHM. Reading the above chart states that using 1OHM, I CANT exceed 475watts.... so if im reading that correctly, i CAN NOT use 12GA if im supplying 1100+RMS watts to each BL under 1 OHM....Correct? Thanks
I love my staffie :good:
So anti FACEBOOK it isn't even funny
If your running 1100 to each sub I'd stick to 8 gauge or 10gauge. When in doubt go bigger, It won't hurt.
HU: JVC KD-AVX1Speakers: Stock BlazerSub: 2 Mass Destruction Car Audio Sidewinder 12"Amp: Orion HCCA-D1200 @ 1ohm (600 RMS)Box: 3.0 cubes tuned to 35
My whole reason for trying to switch over to 12GA wire is so that I can go squeeze 2 wires into the terminals on the BL's, so I can come out of the box with just 2 holes and not 8 like I currently have. I'll show you what I mean, I have a pic of the back side of my box. Im wanting to do the sub wiring internal to the box, and just have my 1+ and 1- wire coming out the box. I'm currently using 8Ga wire and that shit is thick, and can just barely get 1 wire into the speaker terminals.
Maybe try and tin the tips of the 8 gauge then file the ends into a half circle so that when you put them both in the terminal (each one from each side of the terminal) they create a single 8 gauge diameter.
You know what I mean? I wish I could draw a picture or something.
Proud DC owner
  • Who's Online   0 Members, 0 Anonymous, 1576 Guests (See full list)
