Rebuildin' 2003 Grand Am
Resin isn't just for strength. Mdf breathes and when you resin the inside or outside or both it helps to completely seal the box off from getting air into it other than the port. When I resined the outside of my box the score jumped up .2 db by just doing that. Also the resin on the outside helps the airflow over it better, but just doing the inside will help the box from breathing. If you got it handy I would say use it. If not on his box then do so on your own. Every little bit helps in the game of dbs.
2013 VW Jetta GLI 2.0 Turbo
1 Sundown Audio SCV2000
1 Sundown Audio X15 V2
1 XS Power D3100
Audio Control LC6i
Stock Deck
2001 Focus ZX3: RETIRED
Highest NSPL Scores to date:
finished building lucas' box.... again this box is strong... itll be like concrete after the resin
heres a pic of the dowel the supports the sub, and the other two screwed to it
Posted Image
finished besides paint/stain and 3/4" roundover for port
Posted Image
Tomorrow and Tuesday I'll be building my box and finishing Lucas's
(4cuft@30hz w/58sqin port w/resin+mat)
Amp Mount w/Decal
Posted Image
vacuumed the box inside and out with my baby girl in a papoose/snugli (for dads who know what those r)
she seemed like she wanted to get in so... what the hell
Lilian investigating my secrets to box building
Posted Image
as usual shit came up and im stalled on making my box til monday/tuesday.... had to work days i normally dont cause i got a wedding to go to this weekend
but i did purchase something....
_______________________________________________________________
Purchased From:audiosavings
Item # Item Title Quantity Price Subtotal
RE AUDIO SX12D4 12" 2000 WATT DVC CAR SUBWOOFER SX12-D4 1 $209.00 USD
Shipping & Handling via Standard Delivery to 601XX
(includes any seller handling fees) $0.00 USD
Shipping Insurance (optional): $4.60 USD
Total: $213.60 USD
one more to buy today 10/23 and ill be bassin' soon
not a bad price id say, local dealers were $60+ more
been a busy bee... broke a plastic clamp so i still have the outer port wall to put on plus two 45s.... but its looking good
Posted Image
got bracing...??? i sure do
Posted Image
i tried to keep all the glue off the wood so i can stain the front and back so im happy with that too... looks clean on the outside...almost nice enough to not even stain it
im not very happy with the cuts i got from my wood cutter but i got it to work... and he forgot to roundover some pieces but for all i know i might build another box after this to maximize the subs once i get a feel for them
1st sub arrives tuesday!!
Both boxes look good man. I think that you'll be happy with the SX's. I had a single one off of 1200 watts doing 139's in my Escort with a trunk. Two off of the amp that you're using should shine quite well in the car that you have. The subs have very nice low end response as well, so lows aren't a problem with them and getting loud will also be expected http://www.stevemeadedesigns.com/board/public/style_emoticons/default/hairtrick.gif
1 XS Power D3100
Audio Control LC6i
Stock Deck
yeah i know both boxes look pretty similar but strength wise... they are the strongest to date without using resin that ive made... i cant wait to hear the [email protected] in the eclipse... should really help the lows going from 3@33hz
ive spent many days comtemplating between 2 12" re sx or 2 12" aq hdc3... went with the sx cause its much happier with 2200w... i think id need the aq3500d to satisfy the hdc3s
ive also never seen the "re" for a dual 4 ohm re sx... since all the specs are on the dual 2 ohm...
so im hoping its like the re se and a dual 4ohm is actually 2.8ohm.... thus the amp will see .7ohm which will help counter my box rise
broke a 1/8" wood bit last night too so cant finish til later today... its moving along...slowly
