Rebuildin' 2003 Grand Am
small update
2nd 12" sx will be here wednesday!!!!!!!!! w00t!!!
if i put all my eggs in one basket i think ill be bassin' by the weekend.... i hope... im having withdraws
i still need fuse holders and speaker wire
and whether to use bolt terminals (do you use brass?)
or 10ft of 10gauge and go outside the port
and whether i should attempt to put t-nuts in with the top already on.... i think im going to do 4 t-nuts and 4 screws after the nuts have been tightened cause i cant get a hammer in the box for ~4 of the needed holes
now if only i didnt work id have some damn bass!
Posted Image
i love the finish man! i think a little bit darker stain will be better.
small update
wire the subs up with 8ga if you can but if you already have 10g then that will work good too. as for the terminals i'd say you the bolts, washers and nut method. get ther copper or aluminum bolts and you should be good to go.
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
yeah... so i mentioned earlier that i fucked up the wood cause i let too much glue sit soooooo... its actually just sealed... no stain... just some rough poly... it will be painted eventually but first i gotta hear what it sounds like incase i need to make any changes
so heres what im doing
(4) twisted knukonceptz karma 10gauge from each voicecoil to box terminal which = ~3feet... each run will only see 600w rms @ 2ohm
then from outside of box terminal to amp (2) twisted knukonceptz karma 8 gauge = ~2 feet
that is technically overkill for only 2200w rms for speaker wire
wire should arrive tomorrow 11/20
4 screws per sub then ill screw down the 4 t-nuts... i only used 10/24 t-nuts so ill use a small washer to get the diameter of a drywall screw.... this should be fool proof
Posted Image
knukonceptz karma smoke 2 channel rca for sub amp... replacing my rf comp rcas... i never liked them
Posted Image
300a inline fuse holder for under the hood.. its bigger than i expected... my fav fuse holder so far
Posted Image
where the magic happens... haha...the cluttered life of parenthood/workaholic
Posted Image
the workshop.....lol..... sad but true.... the best handymen need very litttle space... to bad i cant sand anything..haha
Posted Image
waiting on wire from ups... i thought it was coming today... noop... so maybe tuesday ill fire these babies up
almost done, i got this wire cheap from knukonceptz, left over runs at the end of rolls ftw!
twisted x2 10gauge for speaker to box terminal... ready for crimping and soldering
Posted Image
twisted x2 8gauge from box to amp on top
Posted Image
8g vs 10g
Posted Image
back of box
Posted Image
inside
Posted Image
just need my local shop to finish the ring terminals
let us know how it sounds.
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
