Left front (+/-) Tan/Gray
Right Front (+/-) Light Green/Dark Green
Left Rear (+/-) Brown/Yellow
Right Rear (+/-) Dark Blue/ Light Blue
(incase you cant read it)
Chode69, kylecm85 thank you guys very much for this information!!!
I'm probably gonna do it myself to save my co-worker/friend some cash.
Derp.
either gonna need a Metra GMRC-03 or a 70-2020
one is a bypass (70-2020) and one an integration i believe.
theres MOST LIKELY a factory amp in there. hopefully you dont have to do a full amp bypass. those are bitches....
i normally just do full bypasses...... which really suck.....
those colors are only good if you dont have the six or eight speaker system......
2003 Toyota Sequoia
Pioneer 4100dvd
Memphis PR6.5 3ways in all four doors
Memphis PR 15s (4)
Memphis PR 1.1000 (2)
Memphis PR 4.50 (1)
Optima Yellowtop (2)
Viper 5901
8000k H.I.D. kit
15% tint (2layers)
i hate to thread jack but this topic is right on. i have a 1996 cadillac deville concour with the factory amp and 11 speaker system. well i replaced all the door speaker with componets and ran a aftermarket amp with and aftermarket head unit. i bought the metra gmrc 03 wire harness and hooked it up and every thing worked but my battery drains over night so now i pulled the 40 amp fuse for my factory amp and every thing works and my car does not drain down. but now my head unit has no memory and have to manually turn it on every time i let the car sit for over 5 minutes turned off. any idea what i did wrong?
sounds like you hooked up the amp turn on to a constant instead of switch power. also is your red wire from the radio hooked up to the yellow to the car?
Edited by Chode69
NoFearX18 said:
trainman0978 said:
I know my aftermarket amp is turning off when the car is off but I do not remember what wires I hooked up but I will pull it out and look. Now I'm hearing other guys running wires all the way from the headunit to the factory amp I didn't use no harness like that
To my memory I went red to red and yellow to yellow was that wrong
should do yellow from radio harness to orange of factory harness
and then red from radio harness to yellow of factory harness.
im pulling up your info and its saying your power wire is orange accessories is yellow so thats how i factored what is aid above.
NoFearX18 said:
trainman0978 said:
well that kit that i bought came with a buzzer and a harness that i plugged in to and it had wires coming off it that were matching my colors on my headunit. i might have to get a test light and check it out. just thought they would match up the colors.
well try the 2 wires i told you about and see what it does
NoFearX18 said:
trainman0978 said:
  • Who's Online   0 Members, 0 Anonymous, 2647 Guests (See full list)
