gd pm guys i need your help here..im planning to install a 1 15" on a suv..the sub. gonna use is audiobahn natural sub...i want it to be streetbass loud and low...no space limit....
fs 28.2hz
qts 0.49
qes 0.55
qms 4.65
thanks guys...
  • 2 months later...
I have the design for this:
its 3.5 net @ 30hz. so the box gets down and plays low. its 41.5 wide and 18 high. i have the plan for it still if it would work.
Ford Explorer 2000
4 12'' Type R's under window line
Legal: 155+ dB
  • 3 weeks later...
max output for 1 15" sub would be a T-line enclosure if you have the space.
Whaaaaaat?
Yeah, because all the world's loudest dbdraggers are running t-lines... :01nocomment8so:
That said, yes, a t-line would probably suit you seeing as you have lots of space and want strong lows :)
10.x volts fo' life!
Whaaaaaat?
Correct me if I'm wrong, but I think T-line referrs to a transmision line enclosure. They are super efficient, true, but aren't they also super tricky to build. That is unless you're willing to measure your speaker parameters yourself and build a few test boxes...
i'd vote no t-line, the t/s specs on that sub dont look like the kind that reacts well to the near free air resistance of a t-line, a more traditional ported box is probably your best bet
just my .02, you're going to spend more on glue than the sub, why would you really build a custom enclosure for a 40$ sub from a company that does'nt exist anymore?
If i knew how to convert t/s into volume and port size i'd help you out, but thats a bit beyond me right now, if anyone has the formulas feel free to share
Team DC
Yep t-line = transmission line.
Indeed they're very efficient but they don't offer much in the way of cone control which limits the amount of power you can give them... at the end of the day a ported or bandpass box with LOADS of power is going to be louder than a t-line which is limited by the mechanical power limits of the sub in that particular enclosure.
If you know the parameters of the sub it's not all that hard to build a t-line. Sure it's a bit more complex than a regular box but nothing crazy. A lot of people on here have built them without going to the n'th degree with the technical stuff and still got very good results.
  • Who's Online   0 Members, 0 Anonymous, 1800 Guests (See full list)
