Bonappetit Posted August 28, 2008 Report Posted August 28, 2008 Sundown 3000d @ .5 1 g34 deka under the hood and 3 g31 dekas in the rear(total of 4 batteries). 250 amp mechman alt big 3. Whats everyones voltage opinions? Team Sundown 3 15" Sundown Nightshades 1 RD HW D9 amp 10.5 cubes tuned 30hz
wL<3bass Posted August 28, 2008 Report Posted August 28, 2008 I have no idea but I predict mid to low 13s edit: under tones Vehicle: 1997 S10 Blazer 4dr 4X4 Exterior: Rear End Bagged, Black Grill, Lifted 2" Amplifiers: Rockford Fosgate T8004 & T10001bd Batteries: 2 Stinger SPV35, Kinetik HC2400 Electrical: Big 3, DC Power 290amp Alternator w/ MLA at 15.5v Enclosure: 4.2 ft³ @ 33Hz 84sq.in. of port (20sq.in. per cube) Headunit: Eclipse CD3200 w/ 80G iPod Mids/Highs: Rockford T152s (a-pillars), Rockford T162s (doors) Subwoofers: 1 15" Fi BL Fully Loaded Wire: All 1/0g Kicker Hyperflex My YouTube Videos My Fiberglass A-Pillar Build My "Seamless" Looking Box Build My DD1508 T-Line Bandpass Build "Seamless" w/ Acrylic Windows (for '05 TrailBlazer) My Stealth 8" Fiberglass Build (for '05 TrailBlazer) My Build For A Friend's '08 Cobalt 15" BL Sealed Off From The Trunk My feedback/references...
Krice420 Posted August 28, 2008 Report Posted August 28, 2008 yea you shouldnt have to bad of a voltage drop with that setup since youll only be pulling around 200 amps worth and you gotta 250 alt and those batts. id say low 13's 2 18'' fi btls fully loaded 2 sundown saz 3000d 1 iraggi 200 amp alt 3 powermaster 3100d series batts 11.75 cuft wall after displacement tuned to 31.08 hz
sully Posted August 28, 2008 Report Posted August 28, 2008 what is the alt output at Idle and what size pulley are you running? Should be just fine, you should consult the guys at MLA and see if they have a product to control that new alt. 2003 Ford F-150 Reg Cab layin body on 26's 2003 Tahoe 3/5 drop on 26's with a 408cid Supercharged engine. 2011 Camaro 2SS 2005 VW GTI Stage II ECU, CAI, 3" turbo back exhaust, FMIC, lowered 2" on some plastidipped 18's 2003 Hayabusa lowered, stretched, cams, nitrous and custom paint
