E-Train Posted August 29, 2008 Report Share Posted August 29, 2008 Okay what kind of pioneers are you gonna be getting Quote 1997 4 Runner Alpine CDA-9886 4 Fi Audio X Series 12's 1 Crunch GP3000D Pro DC Power Inc. Alternator(Kickin out 15+ volts!) Link to comment Share on other sites More sharing options...
ScottyBoii Posted August 29, 2008 Author Report Share Posted August 29, 2008 Okay what kind of pioneers are you gonna be getting 2 12" 1200 watt pioneer champion 4 ohm. i have 1 already i just gata get another one and get a dual box Quote Link to comment Share on other sites More sharing options...
Beanz Posted August 29, 2008 Report Share Posted August 29, 2008 get a fosgate or a hifonics a lil overratted but it'll do the job.I'd say since the RMS on those is i think 400 go with a 600-900 rms mono block amp. Quote That's why they don't deliver. Yer ass better go sit along the side of the road and wait. You can't expect them to travel up some dirt road in a hick / back woods town. Thats how horror movies start I explain things very simply and use analogies in terms of Pickles, and grape drink, pool noodles and jackhammers...if you can't put 2 and 2 together there man, There simply is not much more I can do. Link to comment Share on other sites More sharing options...
ScottyBoii Posted August 29, 2008 Author Report Share Posted August 29, 2008 get a fosgate or a hifonics a lil overratted but it'll do the job.I'd say since the RMS on those is i think 400 go with a 600-900 rms mono block amp. i dont g et wat the mono, 2 channel, multi channels things mean? Quote Link to comment Share on other sites More sharing options...
E-Train Posted August 29, 2008 Report Share Posted August 29, 2008 Okay well I looked up the specs for em and it says they are only 400RMS, so for 2 of them if I am correct get a mono amp stable at 1 Ohm, that does 800 Watts Rms and for a box a ported box would probably be best Quote 1997 4 Runner Alpine CDA-9886 4 Fi Audio X Series 12's 1 Crunch GP3000D Pro DC Power Inc. Alternator(Kickin out 15+ volts!) Link to comment Share on other sites More sharing options...
ScottyBoii Posted August 29, 2008 Author Report Share Posted August 29, 2008 Okay well I looked up the specs for em and it says they are only 400RMS, so for 2 of them if I am correct get a mono amp stable at 1 Ohm, that does 800 Watts Rms and for a box a ported box would probably be best ok thnx alot Quote Link to comment Share on other sites More sharing options...
Sampsonite Posted August 29, 2008 Report Share Posted August 29, 2008 IDK of any amps stable at 6ohms.... My soundstream Tranatula took 6 ohms fine Quote --Sampson 816-591-6592 www.kcrimshop.com Link to comment Share on other sites More sharing options...
andym85 Posted August 29, 2008 Report Share Posted August 29, 2008 amp question=amp section...moved Quote i likes me some audio stuff... Link to comment Share on other sites More sharing options...
Boon Posted August 31, 2008 Report Share Posted August 31, 2008 An amp doesn't have to be specifically 6 ohm stable... if it's 2 ohm stable then it's also 3 ohm stable, 4 ohm stable, 5 ohm, 6 ohm, as well as 22.345563463 ohm stable. Quote 10.x volts fo' life! Link to comment Share on other sites More sharing options...
MickyMcD Posted August 31, 2008 Report Share Posted August 31, 2008 An amplifier will be stable into any impedance above the heat threshold impedance. So if my amplifier is listed as stable to 2 ohm, then anything above that (as long is it is not inductive or reactive, that's a wee bit more complicated) will be fine. Even 100,000,000ohm. Just don't expect much power. Cheers, Mick Quote Work;DiGiCo D1 Live / MIDAS Heratige 1000 / MIDAS VeniceMeyer Sound CQ-1's, CQ-2's, PSW-2'sRAMSA Monitor AmplifiersP.Audio MonitorsBSS OMNIDRIVE and SoundwebDBX 231 and Klark Teknik DN360 EQ'sRCF TT22ARCF ART320 Link to comment Share on other sites More sharing options...
