Quick Question Coax + Tweeter?
Got_Bass89
So i have 4 coax's and 4 extra tweeters all ran off the deck right now. Just a coax + tweeter on each channel. Sounds real good but not blaring like they would be on a amp.. I know I know i need get components but i got stupid 4"s up front and 4x6s in back.. So ima have to start cuttin or fiberglassin.. Anyways I was thinking about ampin them... What kind of load would that be on my amp?
Passport Build Here
Alarm: Prestige APS997A 2-Way/Remote Start
HeadUnit: Pioneer DEH-P6000UB
Front Battery: Yellowtop Optima D34/78
Back Battery: 2x C&D Technologies High Rate Series UPS12-475FR 134AH
Subs: 2x DC Lv4XL 18's
Amps: 2x Sundown Saz1500's Strapped
Box: 12Cubes 33hz 185sqin Port(15.4sqin per cube)
Pillars: AudioBahn AS31Q
Front Doors: Clif Designs TX40.5
Back Doors: Clif Designs CD50.4C
Rear Speakers: Clif Designs TX46.5
Front/Rear Amp: Kicker ZX350.4
Back/Pillars Amp: Kicker ZX200.2(Looking for another zx350.4)
Electrical: 1/0 Scorpion Wire 2 Runs Pos and 2Runs Ground, Knu 1/0 Flex Running to Amps ect, Big 3, JL 8Ga For Speaker Wire, Knu Karma RCA's, Scorpion Volt Meter
Deadener: 100 sqft Sound Destroyer Mat And SECOND SKIN Damplifier Pro Door Pack
Ya 4"s still kinda hard to find but i've seen the focals and stuff.. But then i'd amp those and leave the rear off deck... Don't really wanna do that.. wanna amp them all.. I have time to setup amps but not fiberglassin and rippin my truck apart when i drive it everyday to school and stuff.. Sucks commutin to college.. need buy a little beater car lol...
Passport Build Here
you can easily put some 4" comps in the rears as well. All you need to do is make some block off plates.... remove ur stock speakers and trace the outline and cut the pattern out of wood then cut a 4" and tweet hole and your done
But back to your original question if you have a 4 ohm speaker and you add a 4 ohm tweeter you should get a 2 ohm load
J. Jsig_253411.jpgMy CardomainFINISHED COBALT SS/SC DUAL ALTERNATOR PICS icon_nuts.gif
theres no such thing as too expensive when it comes to upgrades like that, because imo if you are gonna spend to upgrade then do it correctly rather then be a cheap ass ricer
Well the problem is I donno what ohm the tweeter is doesn't say on box... Box only says Feq 1k-20khz, 91db, silk dome, blah blah.. No ohm.. So you think they're 4ohm tweeters? That means my deck can run 2ohm? Interesting... What would the ohm load be if the tweeters were 8ohm and speakers 4ohm?
Also I cant do the plate for the back not enough room already thought of that...
Passport Build Here
all the tweets ive had that ive checked the ohm load on didn't register anything, i got a 6&1/2'' componit set up front and a 6&1/2'' set of coax with extra tweets and my ohm load on the amp is 2ohmx2 so no harm in the headunit at all, but if u were to get an amp, ur best bet is a 2channel cause it will get alot louder if i u have a 200w 2channel than a 200w 4channel cause u can wire a 2ch to 2ohms per side and get 200wrms or u can wire a 4channel at 4ohm on each channel and not get half the power u need from it, ied get a 2channel amp for all the speakers so u can have it ona 2ohm stereo load and get a cleaner signal than tryin to get the same wattage from a 4channel at 4ohm, and for a componit set u can look here http://www.woofersetc.com/index.cfm?fuseac...rt=account_name and its a good website thats were i got my sub amp, headunit and componit speakers, and they only go my price of the stuff on shipping not weight, hope this helps u on ur search, ied get 2 good sets of 4'' componits and put one in the front and make a board like he said and cut it out to the diamiter of the 4x6 and put the speaker on one side and tweet on the other and ur good to go
here's a link to my system 99 toyota tacoma , 2 mtx 8000 1504's in a sealed downfire , 1000w memphis amp
here's a link to my other system my 90 geo prizm test car
heres a thread i got of new songs u can dl that are legal = Some Good Bangage/you Can Dl These Free And Legit
as for the plate, just make a board the same size as the 4x6 and cut out little grooves to go over that metal bar and put em in those should work
Cool cool thanks roscoe... And tacoma thanks for all the amp info... Already knew but thanks still.. Like i said i don't think i can get a 4" in there but ill see what i can do tomorrow.. Bust out some cardboard and try make a prototype heh.. What i'm really thinkin bout is gettin a 4ch to run each coax + tweeter on each channel so it will be a 2ohm or 2.6ohm load and add a center stage in back doors... 6 1/2 component set ran off 2ch... Now to decide what amps to run would like to get matching..
Passport Build Here
  • Who's Online   0 Members, 0 Anonymous, 1013 Guests (See full list)
