honda Posted September 12, 2008 Report Posted September 12, 2008 with my current set-up, I have two diamond D6 12" ported powered by AQ1200d which is giving the subs their max RMS power handling. It's juz not enough for me anymore. I was thinking of adding another D6 12" for a total of three subs but in sealed enclosure due to limited trunk space and also buy the bigger AQ2200d amp. The three subs are DVC 4ohms so the i would wire the DVC in series to get 8ohms per sub and then run each subs in series which yields to about 0.9 Ohms total for all subs. This set-up would give about 740Wrms per sub. my questions are: 1. will these three subs in sealed with a bit more power be louder than the two ported set-up? 2. Also, will taking the 6x9's on my reardeck help get the sound get in the car more? (2006 accord) 3. any other suggestion for me to get louder (i'm trying to keep what i got ryt now and juz add but if you got a better idea for me to get louder with a about a $500 bucks budget help me out) ? My Soundz: '06 ACCoRD Diamond Hex (front)........................Diamond 2ch x 100Wrms............................Ought-guage Power wire and BIG THREE Diamond 6x9 (rear deck).................AudioQue AQ1200d @ 1ohm........................MTX re-Q (sound processor for stock HU) CDT tweets (rear doors)..................Alpine 4ch x 45Wrms.................................Clarion 7band EQ TWO Diamond D6 12" DVC 4ohm Coming soon upgrades: Batts dynamat trunk kit
briankarmilowicz Posted September 13, 2008 Report Posted September 13, 2008 if im not mistaken your ohm load is wrong. if you made them 8 ohm the three would give you a 2.something load ohm load not .9
wL<3bass Posted September 13, 2008 Report Posted September 13, 2008 if im not mistaken your ohm load is wrong. if you made them 8 ohm the three would give you a 2.something load ohm load not .9 2.67 and two ported should get much louder than 3 sealed. Vehicle: 1997 S10 Blazer 4dr 4X4 Exterior: Rear End Bagged, Black Grill, Lifted 2" Amplifiers: Rockford Fosgate T8004 & T10001bd Batteries: 2 Stinger SPV35, Kinetik HC2400 Electrical: Big 3, DC Power 290amp Alternator w/ MLA at 15.5v Enclosure: 4.2 ft³ @ 33Hz 84sq.in. of port (20sq.in. per cube) Headunit: Eclipse CD3200 w/ 80G iPod Mids/Highs: Rockford T152s (a-pillars), Rockford T162s (doors) Subwoofers: 1 15" Fi BL Fully Loaded Wire: All 1/0g Kicker Hyperflex My YouTube Videos My Fiberglass A-Pillar Build My "Seamless" Looking Box Build My DD1508 T-Line Bandpass Build "Seamless" w/ Acrylic Windows (for '05 TrailBlazer) My Stealth 8" Fiberglass Build (for '05 TrailBlazer) My Build For A Friend's '08 Cobalt 15" BL Sealed Off From The Trunk My feedback/references...
alvitae Posted September 13, 2008 Report Posted September 13, 2008 if im not mistaken your ohm load is wrong. if you made them 8 ohm the three would give you a 2.something load ohm load not .9 I think you are right, I come up with 2.67 ohm. Paralle/parallel you'll get .67 ohm if i'm not mistaken.
