Technical Amp Question (ohms)
98HOEONSIXEZ
Just wondering if there is a general rule of thumb,or a % an amp gains when going down in ohms.. . okay no amp to be specific but just making one up to use as an example.. . .Lets say you have an amp that puts out 1000 watts rms at 2 ohms,then 2000 watts at one ohm,. . .say if you wired it down to .75 or .50 or .25 how do you calculate how many more watts your getting?I know that the amp has to be stable to go down that low.This "example amp" that i made up lets just say its stable to .25 ohms.And we have a steady 14 volts to supply it with.So the question is what % of watts are you going to go down each step in ohms you go?or does it always vary?
thanks
jprice
use a dmm and a clamp meter to figure out the wattage you're getting.
No. You don't know how the amp will respond to lower impedance - the efficiency of an amp rapidly decreases at low loads and it's not linear... no way to know without trying it.
10.x volts fo' life!
  • Who's Online   0 Members, 0 Anonymous, 807 Guests (See full list)
