Can anyone tell me the amp draw on these amps? I have a 180 amp alternator and want to know if I can run one of these. Also if so will I have to put another batt in the truck?
Eclipse
Hifonics
Alpine
Kinetik
Optima
Excessive Amperage alt
are you going to be using both in ur car or are these future purchases
~350a fuse is needed for autotek... i think 250a for the hifonics
so ~300a max and ~200a max... guestimation
yes you would need another batt(s) probably another 3 hc600s at least
Edited by decafcappucino
I will be using just one of them. I did not purchase it yet though.
Eclipse
Hifonics
Alpine
Kinetik
Optima
i'm sure the 200 amp alt will do with two or three good batteries ... be sure to do the BIG 3 and maybe add the MLA module for the extra kick.
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
yeah you dont need an alt that supplies the max draw of ur amp....
alt charges bats
bats hold power to supply to amp
mla is when both have sex and the baby is extra voltage
Cool guys, Will my 180 amp alt work ok? I would get an extra batt too. and the MLA module. I have the big 3 done already.
Eclipse
Hifonics
Alpine
Kinetik
Optima
you should be good to go potna. what batteries are you thinking about going with?
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
I will get a yellow top up front if it will fit. And use my Kinetick 600 in the rear until I can buy one.
Eclipse
Hifonics
Alpine
Kinetik
Optima
stick with kinetik and get the biggest that fits under the hood and get either 3 or 4 more hc600s... or two hc2000 or two hc1800 would prolly be enough
u should be able to fit hc800-2000 under the hood in most cars
edit*
kinetik site says for autotek4000 (2)HC2000
kinetik site says for hifonics2608 (2)HC1400
  • Who's Online   0 Members, 0 Anonymous, 911 Guests (See full list)
