byron2817 Posted September 17, 2008 Report Share Posted September 17, 2008 well i just decided to get Loud mids & tweets so im going to get some 8" for doors but i wanted to know how easy it it to make door pods? i made the ones for pillars but not for doors.i want something like thse http://www.projectxcustoms.com/wp-content/...ads/wppa/27.jpg simple that i could remove if i want to.im getting all new mids & highs set up NEED TO GET LOUDER!!! Link to comment Share on other sites More sharing options...
The Performer Posted September 17, 2008 Report Share Posted September 17, 2008 Draw it out first, build a frame from mdf, 1/2" outta do. Once you get the frame stretch the ponte/fleece (ponte is probably going to be easier since it's small curves) Then put a few layers of glass, sand, fill, sand, primer, paint, and attach. Can you post a link to the pillars you did? So we can see what kind of experience you're talking about. CERTIFIED BITCHES!!! Not being new at something doesn't mean anything. Just because a prostitute isn't new at what she does, doesn't change the fact that she still 'sucks' Click to see my build! Proud DC owner Link to comment Share on other sites More sharing options...
byron2817 Posted September 17, 2008 Author Report Share Posted September 17, 2008 ii just have this pic where u can bearly see them.i take pics tommorow. NEED TO GET LOUDER!!! Link to comment Share on other sites More sharing options...
raytard Posted September 19, 2008 Report Share Posted September 19, 2008 Read my build log in my signature, the fronts were full fiberglass fronts and rears, the backs were a MDF base with fiberglass fronts. Truthfully, it was pretty easy, just a bit of work. All of mine are theoretically removable, the front's have a pocket I can reattatch, and the rears i can unscrew and re-cut carpet to cover the holes. If you have any questions, i'm sure someone on here can help Build: http://www.stevemeadedesigns.com/board/ind...hl=avalon+build monster/rockford/kicker/stinger cables, pioneer source, jbl highs/amps, kinetik/shuriken batts, iraggi alt, dei security, dc subs(atleast for now) Team DC Link to comment Share on other sites More sharing options...
loganberry Posted September 19, 2008 Report Share Posted September 19, 2008 great work raytard that helped me too!!! i have a question tho, whats easiest way to seal the pod to the door? screws or what u use My F-150 Build GET ON THE BANDWAGON what if they tried messing with the amps when the subs werent louder hahah jk Link to comment Share on other sites More sharing options...
wasted ink Posted September 19, 2008 Report Share Posted September 19, 2008 theres a million different ways... i try to glass in bolts before i stretch the fabric... then once theyre in place, line it up with the door, drill some holes and put nuts on the back... if your pod is over your factory clips, and isnt too too heavy, you could possibly use automotive trim clips to fasten it in... it all depends on your door panel and the way the pod was built... Wasted, Incorporated Up Front: Optima Yellowtop HU:Pioneer Avic N1 w/ 2007 upgrade Front Stage: MB Quart 6.5 comps Rear Fill: Infinity Reference Sub Stage: RE MT 18 Sub Amp: Undecided Sub Enclosure: 5.5 cubes tuned to 33hz Absolute Terminals SkyTec 5100RS 2-Way LCD Pager KnuKonceptz Wire My Build Log Link to comment Share on other sites More sharing options...
raytard Posted September 20, 2008 Report Share Posted September 20, 2008 i should've taken pictures, but as you can see, mine are a fully enclosed pod, and basically i just seated them where i wanted them and ran 8-10 large head 1.75inch coarse thread zipscrews from the back into the pod. The front ones are like 6ish layers of fiberglass, and the rears have 3/4in mdf backing, so they've been fine thus far, they definitely wiggle if the door is slammed, but thats more the panel flexing off the door than the pod flexing off the panel, the doors are secured with 2 large bolts in the center, the top has the window seal hanging thingy, and the bottoms had like little screws, but they wer eon the pocket, and gone now. The people i spoke to about how to attatch it said to keep it simple, either screw it in if you ever want to remove them and make it easy to redo (like I'll do later when I wrap them in vinyl) or drill through the door and pour epoxy on it, and let it set to be permanently attatched. Build: http://www.stevemeadedesigns.com/board/ind...hl=avalon+build monster/rockford/kicker/stinger cables, pioneer source, jbl highs/amps, kinetik/shuriken batts, iraggi alt, dei security, dc subs(atleast for now) Team DC Link to comment Share on other sites More sharing options...
