Forevrbumpn Posted September 19, 2008 Report Posted September 19, 2008 cool... 1 pcb huh, not dual mono blocks? well that is interesting then, and impressive... hope its not rated $1- 1 watt- maybe $0.25 per 1 watt heh I have a ritual called "terminator". I crouch in the shower in the "naked terminator" pose. With eyes closed I crouch for a minute and visualize either Arnie or the guy from the 2nd movie. I then start to hum the T2 theme. Slowly I rise to a standing position and open my eyes. It helps me get through my day. The only problem is if the shower curtain sticks to my terminator leg. It sorta ruins the fantasy.
RHoughton1 Posted September 19, 2008 Author Report Posted September 19, 2008 I wouldent think so, they just had a build thread for it a while ago http://www.stevemeadedesigns.com/board/public/style_emoticons/default/hairtrick.gif Do you have a link to this build thread. Thanks. 'If it ain't broke, don't fix it,' unless you're a tweaker, and in that case you already fixed it ten times and it's still broken. - Dave Mustaine
joshua_in_michigan Posted September 19, 2008 Report Posted September 19, 2008 reason for the 2 remotes, and multiple powers is its just 2 mono blocks under 1 casing right? But still, 4 power/4 ground? must have massively insane specs Edit: based on the post right before mine, its not as big and bad as I thought, unless it was 1ohm, or 0.5ohm capabale but none the less, impressive to some extent i must agree. kinda thought higher specs... and maybe 12v testing -shruggs- that'd be nice lol!so hopefully im guessing thats RMS power.... ill just assume. if they arent under 1k, then im thinking RF T4 is the way id go Whats urs? hehehe - post in ur sig
dwright27 Posted September 19, 2008 Report Posted September 19, 2008 i must agree. kinda thought higher specs... and maybe 12v testing -shruggs- that'd be nice lol! so hopefully im guessing thats RMS power.... ill just assume. if they arent under 1k, then im thinking RF T4 is the way id go those number where at 2 ohms. you cant get a brand new T4K for under $1500 and the T4K wont do 6000 RMS @ 2 ohms. if you can get on of the for around 2 G's then i say its well worth the extra $500. 2006 F-150 4 DC XL M2 18's Walled Daily Driver XS Power 4 DC 3.5kw Team DC Team S.P.L. Lot of Audio Technix and 1/0 DC Audio Dealer American Bass Dealer XS Power Dealer Audio Technix Dealer
RHoughton1 Posted September 19, 2008 Author Report Posted September 19, 2008 those number where at 2 ohms. you cant get a brand new T4K for under $1500 and the T4K wont do 6000 RMS @ 2 ohms. if you can get on of the for around 2 G's then i say its well worth the extra $500. Supposedly Does 12,000 at 1 ohm and 14 volts,and I don't know what MSRP is.But I run 16 volts so I'm kinda interested in the 16 volt specs . 'If it ain't broke, don't fix it,' unless you're a tweaker, and in that case you already fixed it ten times and it's still broken. - Dave Mustaine
Boon Posted September 21, 2008 Report Posted September 21, 2008 cool... 1 pcb huh, not dual mono blocks? well that is interesting then, and impressive... hope its not rated $1- 1 watt- maybe $0.25 per 1 watt heh 1 pcb doesn't mean it's not essentially 2 amplifiers internally strapped... The doubling of everything makes me pretty sure it's 2 amps - as well as the lack of a master/slave link that you'll find on any high-end true monoblock. Just look at the Fusion FCA-4000D 10.x volts fo' life!
BigPimpin91 Posted September 21, 2008 Report Posted September 21, 2008 Holy Fuck those look likes beasts. Quad Power Inputs. BigPimpin91's Banging Music
dwright27 Posted September 21, 2008 Report Posted September 21, 2008 Holy Fuck those look likes beasts. Quad Power Inputs. times 2 i want 1 2006 F-150 4 DC XL M2 18's Walled Daily Driver XS Power 4 DC 3.5kw Team DC Team S.P.L. Lot of Audio Technix and 1/0 DC Audio Dealer American Bass Dealer XS Power Dealer Audio Technix Dealer
RHoughton1 Posted September 22, 2008 Author Report Posted September 22, 2008 1 pcb doesn't mean it's not essentially 2 amplifiers internally strapped... The doubling of everything makes me pretty sure it's 2 amps - as well as the lack of a master/slave link that you'll find on any high-end true monoblock. Just look at the Fusion FCA-4000D Maybe I'm wrong but I dont see two amps internally strapped?? on the fusion. 'If it ain't broke, don't fix it,' unless you're a tweaker, and in that case you already fixed it ten times and it's still broken. - Dave Mustaine
Boon Posted September 23, 2008 Report Posted September 23, 2008 OOOOps double post, see next post 10.x volts fo' life!
