Cactus Sounds Cs Elt. 12
RHoughton1
Has anyone tested these amps.they look like solid amps just wanted to know Durability and numbers at 1/2 ohm.and current draw.
Here are some pics I found at Termpro..
Posted Image
Posted Image
Posted Image
Posted Image
'If it ain't broke, don't fix it,' unless you're a tweaker, and in that case you already fixed it ten times and it's still broken. - Dave Mustaine
Posted Image
Posted Image
Posted Image
Posted Image
I know someone about a hour away with more then a few elt 12s I believe :yahoo: :yahoo: :yahoo: :yahoo: :yahoo:
lol that thing looks a beast, 2 remote wire inputs :|
DC.jpgDC POWER
well wtf my edit did not work on that post.
The big elt 12s are running the same board as the soundstream and hertz monster amps too. I think cactus and hertz are rated around the same, while the soundstream is far behind.
Here's the numbers that was posted on termpro.
CS Elt.6 60cm X 32cm X 7cm 3kw @ 2ohm.
CS Elt.8 70cm X 32cm X 7cm 4kw @ 2ohm.
CS Elt.12 80cm X 32cm X 7cm 6kw @ 2ohm.
All Test @ 14V.
All amps can be used @ 18V.
All amps have 1 pcb inside.
reason for the 2 remotes, and multiple powers is its just 2 mono blocks under 1 casing right?
But still, 4 power/4 ground? must have massively insane specs
Edit: based on the post right before mine, its not as big and bad as I thought, unless it was 1ohm, or 0.5ohm capabale
but none the less, impressive to some extent
Yes it is supposed to be able to go lower along, with the specs are at 14 volts and its 18 volts capable.
They claim 12,000 watts at 1 ohm.
and its 1 pcb.. not two mono amps in one case.
I know someone about a hour away with more then a few elt 12s I believe :yahoo::yahoo::yahoo::yahoo::yahoo:
Are they for sale or are they in something???
I wouldent think so, they just had a build thread for it a while ago http://www.stevemeadedesigns.com/board/public/style_emoticons/default/hairtrick.gif
DC.jpgDC POWER
  • Who's Online   0 Members, 0 Anonymous, 578 Guests (See full list)
