mhmmmm pancakes withs lots of butter and murple syrip are greaT!
that helps alot!!...lolz
I have somewhat the same problem, but it seems to fix itself daily.
It could be one of two things.
Check the power inputs, mine were loose the first time.
Make sure that the amps aren't ground off each other.
do you mean the grounds shouldnt be grounded together.?
No, I mean check to see if the cases of the amps are touching each other.
they aint touching together..
Ok then, go with the first option.
and whats the first option?..chech the power wires?
