This box is for a 2006 kicker L7 15" 2ohm. Amp: kx1200.1 - around 1350w I believe from the birthsheet
4 ft^3
33hz - not sure if this is good, I just heard I should do between 30-35hz
First I tried 2 3x6" ports and they came out entirely too long for the space I want to keep it within after a change in things in my trunk. I just played around with the carstereo.com port calculator until I came up with something I thought I could work with and thought about a single 14x2" would work good but is that too skinny. All edges will be rounded.
Edited by V1G1LANT3
rule of thumb is no ratios greather than 1:8
so 2:14=1:7
but another is 12-16sqin per cuft
so 4cuft*12sqin= 48sqin minimum... ur at 28sqin bro
tuning is fine... some like higher some like lower so it should be fine
I would make the boxes bigger. about 5.5cuft after for each woofer
what are ur max dimensions for the box
and x2 on ray's comment... ive liked them best in 4.5cuft@32.... but anything near 6 the low end is sooo niice
Edited by decafcappucino
if you exceede the 1:8 ratio by much it makes port noise pretty pronounced, and with some setups the air can get over the speed of sound and make some funky shit happen.
some kid at a car show had a port so tight it almost sounded like it whistled, it was so weird
Team DC
Hey decaf, why shouldn't you exceed a 1:8 port ratio? Wanting to know so I don't make any mistakes designing my brothers box.
more likely to have port noise/increase port velocity... think of it as the whistle effect
yup chuff, whistle, woof, huff it makes all those weird sounds
